if u didnt know
Old Dec 3, 2005
C2i0v0i1C's Avatar
SuperMODrizd
if u didnt know
my car has been down for quite some time now. tonight i called and checked up on the engine rebuild. yes i had a blown headgasket. three cylinders were leakin. so getting that all fixed up and put back together. it will have all new bearings, gaskets, CROWER rods, JE pistons and rings and be retuned. no sleeves do to lack of funds and me being tired of never having a car to drive. sorry to dissappoint on that note but **** happens
and yes while the engine is out im searching left and right for that part number on the driveshaft shop axles that i have and the part number that goes along with them for everyone that was asking me eons ago.
Old Dec 3, 2005
Sick Cycle's Avatar
Sick Cycle is an unknown quantity at this point
nice! ... track time soon, eh?
Old Dec 3, 2005
Michalo187's Avatar
Abortion Survivor
how much hp are you planning on making?
Old Dec 3, 2005
civic01vtec's Avatar
WTF........rebuilding the bottom end for the 2nd time w/o putting sleeves in is like wiping before you poop. It doesn't make sense.
Old Dec 3, 2005
turboengnr's Avatar
DONT PANIC
the stock cylinder with a block guard should hold fine for 250+ whp.
Old Dec 3, 2005
hustlelikem0fo's Avatar
Interesting, I do that all the time.
Old Dec 3, 2005
mugenman's Avatar
"mmmBAHHHH" - vtec y0
hey man let me know when ur heading down 2 lexington 2 pick it up. ill ride down with ya. i cant wait till the beast is done!
Old Dec 3, 2005
Havok2k1's Avatar
Wicked Pissah Admin
get R dun
Old Dec 4, 2005
turboengnr's Avatar
DONT PANIC
your car will be fun as hell when you get it. I cant wait to see some numbers!!
Old Dec 4, 2005
He already hit 250whp at 14psi with the same set-up.
Old Dec 4, 2005
C2i0v0i1C's Avatar
SuperMODrizd
not exACTLY
going with stock sized thickness on the headgasket and installing new rings and rods
Old Dec 5, 2005
allmotor's Avatar
nor cal 7thgens
saw on another forum with someone makin over 300 whp on a d16z6 turbo stock block. Sleeves arent horrible on our mtrs. Rods pistons good tune should be fine.
Old Dec 6, 2005
C2i0v0i1C's Avatar
SuperMODrizd
different engine
Old Dec 6, 2005
turboengnr's Avatar
DONT PANIC
just because they made that much power once doesnt mean they could do it again. I doubt that it would be very reliable.
Old Dec 6, 2005
andyman97's Avatar
Turbo Guru
I don't. But once I get my new turbo, I will be running over 300whp on stock motor daily so we'll see. I've had zero problems with 250 thus far.
Old Dec 6, 2005
Michalo187's Avatar
Abortion Survivor
c2i0v0i1c how much hp are you planning on making?
