has anyone swapped an 05/06 k20z engine yet?
Old Nov 28, 2005
djmota's Avatar
has anyone done this yet in a 7th gen? any issues with wiring? I am swap window shopping. Thanks
Old Nov 28, 2005
HondaLuver's Avatar
Its a celebration bitches!
don't do it, too many diffrent things and headaches with the ecu, kpro isn't working with out a 02-04 conversion on the ecu
Old Nov 28, 2005
CuRiOuSfIsH's Avatar
Back From The Banned!
why would anyone want the headache of converting to drive by wire?
Old Nov 28, 2005
iamboo's Avatar
Retired - SoCal FI Mod
i dunno... maybe you should ask temo... his sig says it all...
01 em2 k24 hybrid
232 hp
191.2 tq
Old Nov 28, 2005
Sick Cycle's Avatar
Sick Cycle is an unknown quantity at this point
k20z1's aren't drive by wire ... afaik. k20z3's are
you can swap a k20z1 ... just get an a2 ecu w/ the adapter harness and you should be okay.
Old Nov 28, 2005
djmota's Avatar
so maybe i am out of touch. 05 and later k20's are drive by wire??
I was hoping to run a stock ecu at first get it cali bar'd then do the hondata kpro retrofit. but if the stock ecu is drive by wire that would be out of the question.
Old Nov 28, 2005
djmota's Avatar
Thanks I didn't think so.
Old Nov 28, 2005
oh wow, my mistake...... what car does the Z1 engine come from? does K24 from TSX have drive by wire.
Old Nov 28, 2005
Sick Cycle's Avatar
z1 is the 05+ rsx-s
z3 is the 06 Si
I think there was also something different about the mounts ... but I'm not sure
Old Nov 28, 2005
ok, thanks, I didnt know there were 2 K20Z engines.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
Paul Harsze
May 20, 2015 11:37 AM
Chronic_issues
May 8, 2015 05:40 PM
MyOtherRideIsBritney
Jan 20, 2002 03:16 PM
Cross
Jan 6, 2002 01:31 AM
