radiator problem ??
Old Nov 27, 2005
mrDFWmechanic's Avatar
radiator problem ??
i was wondering if anybody knows or has done a radiator swap from the b series engines. the half size radiator because i might be doing a turbo setup where the turbo's gonna be mounted differently and i need to make room for it. its gonna be mounted somethin like this ..
Old Nov 27, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
I haven't seen anyone do it, that doesn't mean no one's done it. Just get a double thick if you do, or you'll lose a whole lot of cooling.
Old Nov 27, 2005
EM2typeflex's Avatar
EM2typeflex is an unknown quantity at this point
You workin a turbo setup on your d17 or a b-series?
Old Nov 27, 2005
andyman97's Avatar
Turbo Guru
It'll work. You'll just have to figure out a way to mount it.
Old Nov 27, 2005
i want to do a similar setup like that in my dseries. any idea on what radiator i should use ??
Old Nov 28, 2005
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
just buy a hlaf radiator used in the 99-00 civics.. then go to a machine shop and have then cut off the lower bracket hole and reweld it to the proper location of where you want the radiator...
then take the upper mount and move it to the proper location as well... you might have to drill a hole to put the screw in for the new location
Old Nov 28, 2005
thats kinda what i was thinkin about. i work at a parts store so i have easy access to a radiator, but you think that going to to a smaller radiator will let my car overheat ?
Old Nov 28, 2005
blackdragon's Avatar
blackdragon will become famous soon enoughblackdragon will become famous soon enough
Exactomundo!!
Old Nov 28, 2005
smaller radiator with an oem fan.. YES..
smaller radiator with a hi flow fan then no... this has been proven many times at the dyno in my location... if anything make sure you get a hi flow fan like t-fal or something
Old Nov 28, 2005
AlienX's Avatar
AlienX will become famous soon enough
thana
Jun 15, 2020 07:05 PM
Bruce.Ringler
Jun 18, 2015 08:12 AM
Lunar
May 22, 2015 07:43 AM
ttharper
May 11, 2015 07:27 PM
hokiedad4
May 3, 2015 10:06 PM
