fpr
Old Nov 26, 2005
v8eaterokv6's Avatar
i have a new home do u
fpr
would this fpr work on our car with a return fuel system and turbo. i need one asap but cant afford $150 for a nice aeromotive one http://cgi.ebay.com/ebaymotors/G-JDM...17299980QQrdZ1
Old Nov 26, 2005
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
It's a fuel pressure regulator.. you can make it work for whatever application. if you havent done already you will need to put a fitting on your stock fuel rail to connect the rail to the side port of the regulator. then from the bottom of the regulator goes back to the tank. I'm sure you are aware of all this already.
Old Nov 26, 2005
tfnaaf's Avatar
BLDNPSI Mod
it doesnt seem to have a 1:1 ratio for FPR increase to boost , but im not even using that on mine. Im running straight set PSI and tuned to that
Old Nov 27, 2005
andyman97's Avatar
Turbo Guru
I'm sure you could use it but again, I'm not even using one. If you do consider this, it looks kinda cheap and generic. Just remember that you get what you pay for.
Old Nov 27, 2005
turboengnr's Avatar
DONT PANIC
yea, you can use it..... if you like crap.
there is a reason the aeromotive one is $150+ and that one is $35.
Quality. There is probably no guarantee that the cheap *** one would even hold the pressure constant.
Old Nov 28, 2005
if you dont mind telling me what fuel set up you are using im assuming rsx injectors and emanage.
Old Nov 28, 2005
andyman97's Avatar
Turbo Guru
RC 440's and AEM EMS.
Redviking
Engine DIY
44
Sep 8, 2018 02:58 PM
andyman97
Engine Swaps
29
Nov 12, 2006 08:06 PM
BudDyLeEBoOsteD
Engine Swaps
21
Mar 6, 2005 07:53 PM
BudDyLeEBoOsteD
Engine Swaps
46
Feb 28, 2005 01:01 PM
SpdRcrChk
Apr 22, 2003 05:22 PM
