A quick note about aftermarket fpr's
Turbo Guru
Ok, so I installed my fuel pressure regulator two nights ago and ran my return line finally. We set the base pressure at 45 psi. I had spoken with my tuner and he suggested that I keep the vac line off the regulator until I could tune so that I wouldn't be too rich under boost until I could get retuned.
Well after install, I left the vacuum nipple on the regulator open. Car ran like total *** and booged everytime I gave throttle.
Word to the wise, if you run an adjustable vac referenced fpr, make sure to utilize the vacuum nipple. Apparently, when the engine sees load, the regulator has to adjust for the fuel being consumed. Being that its obviously spring loaded, it has to keep the diaphragm down to compensate for load. Being as our stock systems aren't vac referenced, this was a foreign concept to me but it now makes perfect sense.
Also, for anyone running an aeromotive, do you hear any whining coming from your fprs? I hear a whine and its annoying as hell, lol.
I've always taken into account that if it has a connection it should be connected each time i've been told otherwise it never worked right so you were right. Good luck and lets see the new tune man
no whining in my FPRS are you sure it isn't your pump?
Or some times the line coming from the tank gets dry cause isn't big enough to run that much fuel needed but it only be when you are diving on reving 4k rpm's or up.
ya adj fprs are vac refferenced. i have had plenty of experience with that on my old truck. glad to see things are comming together andy. cant wait to see the finished product. you and mex make me jealous. i want boost. but as said before patience is a virtue. i am saving to build my old b18b for the dc 4 i bought. swapped in a b20b for the time being. its nice having some bottom end LOL you dont realize how much your missing in the vic until you drive something with more power.
it would have been fun to tinker with boost on the d17 but i have a much better platform now. but i still enjoy seeing you guys pioneer this industry.
Mine makes no sound at all. But then again i am running 3/8"ID aluminum fuel line from the tank to the pump and to the fpr.
And my FPR is before the rail. It has its own fuel feed lines to the injectors and its own return line.
7thgen Power Maker
whats the best fpr out there?
depends on your application....
Mine was the best for me because it feeds both fuel rails directly from the regulator and has its own return line. I didnt have to weld a fitting to the stock one like most others do.
But mine is a 2:1 ratio fpr with an input and 3 output ports (-8an) and a return port (-8an) and is adjustable past 100 psi.
Turbo Guru
Ok, so I have everything routed correctly, I'm about 99% sure everything is hooked up correctly. Yet I'm still having problems. The car bogs under any load as if there is a dead cylinder.
After talking to Gery tonight and explaining the setup, he seems to think that the fact I'm using the stock line as the return (being so small) and a hose for a -6 fitting for the feed (significantly bigger) is the culprit causing the fuel pressure to fluctuate because the return can't get the fuel back to the tank quickly enough to give consistant pressure. Anyone have similar issues with this or any other insight?
thats not it.....
Mine runs perfectly fine with the stock line as the return. It may be a defect with the regulator. Try swapping it out and see what happens.
The stock return line is calculated to be able to support a return for more than 400 hp. It should have no problems.....
hm i have the opposite setup.. stock line is the feed and the ssb line is the return. my first regulator wouldnt hold pressure so i swapped it out with a new one and it works fine. only whine i hear is the initial startup when it pressurizes. Willing to bet that the reg is bad.
Turbo Guru
I wonder if its the regulator itself. First thing tomorrow, I'll be checking the pressure with a gauge at idle and while giving throttle to see if the pressure fluctuates. If it does, I'll run a larger line and see what happens. If that isn't the issue, I'll have to see about getting another regulator although this one is brand spanking new.....(I doubt the regulator is the problem.)
And here's the really weird thing. The whining from the regulator was due to an improper seal at the tank lid. So that was causing hiccups this afternoon but other than that, it ran great. Only differences since were; removing the stock fpr and putting a hose in its place and sealing the tank properly.....
I get the feeling if I put the stock fpr back on it'd run perfectly.
yeah i know how you feel.. the back and forth thing is so tiresome. I got so agrivated that my car wouldnt start with that 1st FPR i even sent the rail back to have another bung welded on when come to find out it was the regulator all along. **** happens I guess. goodluck.
i would be willing to bet its the regulator as well. if it couldnt return the fuel fast enought to the tank you would have a higher pressure than you are trying to achieve making the car run rich. if its bogging that could be the issue though. what are your afr's under load when it starts to bog???
Turbo Guru
Unless the throttle is ever so slight, it bogs. Under anything over like 40 percent throttle, the a/f's jump to like 10:1.
I'm about to throw a bigger hose on for the return line in a few minutes. I am thinking this should solve the problem, we will see.
Myika, its not all about HP, If you have a 1000gph fuel pump pumping at 50 psi and a 100gph pump at 50psi the volume delivered is much greater with the 1000gph pump, thus requiring a bigger return line. The more you pump up, the more you need to pump back. It very well could be the regulator, or just the nature of the setup itself. 6an feed, big aeromotive regulator, and a huge fuel rail. I wouldnt trust a 3/16 ID line to return all that fuel. Its just asking for pressure spikes, esp. on deceleration, IE in between shifts.
Turbo Guru
Well guys, I got the setup correct. Plugs were fouled to the max and the car wouldn't start. I swapped plugs and found I had a misfire on #4. Turns out that injector is shot and not spraying. I'll be working on getting it repaired or replaced next week, we'll see what happens.
7thgen Power Maker
So a faulty injector and some fouled plugs huh? What AFR were you tuned to Andy?
Here's a little reading on fuel pressure regulators. There are also links at the bottom of the page.
http://www.shonutperformance.com/FPR.htm
I Hunt Goats, Rams, And Mustangs.
Well least we got it up and running. Hope you get you injector worked out, you call Rc and see if they would fix it? or what? Im still checking on that SRT thing, cause im really currious of it! lol.
Turbo Guru
Paul-my afr's were around 12-12.5 in boost.
The noise has stopped, it was due to the cap not being sealed all the way, the regulator was bleeding the air out of the lines, it isn't whining anymore.
I think the reason the injector went was due to overuse. Everytime I hit 16 psi+, the injectors were maxing out all the way to redline everytime I pushed it hard past 4300 rpm, they were maxing all the way to redline, not a big surprise. I should have put the regulator in a while back. But I wouldn't think of not using it now, I need it to keep the pressure rising under boost so the injectors aren't having to stress as hard.
exacty, so techically the more HP you are running, the smaller the return could (in theory) be, but in reality it doesnt work that way. At idle you are sipping fuel so I'd guess you'd know right off if it was spiking, it would probably load up a lil. I did some thinking about this. As long as the restriction in the return doesnt equal more than your minimum fuel pressure, it shouldn't matter what size it is. I still wont ever run more than 1/16 smaller on my return lines. I'd still rather be safe and go a lil overkill.
^ wish I could tune my car that lean. Temp changes here are so drastic I end up running 11.0 in the few months of summer we have, if I dont retune. Better safe than sorry though. Cape Cod weather = poop. Anything under 11.8ish on 93 is ok for me.
Turbo Guru
Well, I am thinking I'll be going to Tony Paolo at T-1 when I retune. I've heard nothing but good things about him. While he's not the cheapest I can get, for the amount of power I'm going for, I need a safe, good, reliable tune.
750's are being ordered this week. FPR is working right. All I need to do is get the cam, springs and retainers in the head, then I can retune. Probably the week after this coming I'll be heading that way.
Touge
Ottawa
Jun 5, 2015 11:15 PM
