mechanical drawing for a garrett t3 turbo
Old Nov 4, 2005
black01civic's Avatar
From: Mukwonago, Wisconsin....around the Milwaukee area
black01civic is an unknown quantity at this point
Exclamation mechanical drawing for a garrett t3 turbo
wondering if anyone can tell me where to find the specs on a garrett t3 turbo i've already checked the website and they have nothing...what i'm looking for is the type of threads that go into the boost side of the turbo.....the line that goes to the waist-gate what that hole thread size is
Old Nov 4, 2005
tony_buttons's Avatar
I'm unusually bored.
tony_buttons is an unknown quantity at this point
Here is the best one I could find.
Old Nov 4, 2005
Nitto's Avatar
gone
Nitto will become famous soon enough
LMFAO dude you own
Old Nov 4, 2005
iamboo's Avatar
Retired - SoCal FI Mod
LOL!!!!!!!!!
Garrett T3 turbo's all have different specs... there are several different kinds and variations of the t3 turbo.... you just want to find the one that best fits the car...
oem t3's off factory built cars have a a/r .42 48 trim... then you have the modified one that are usually higher like the 50 trims and super 60's... it all depends on what you want and your goals for the car...
Old Nov 4, 2005
Exclamation
i already have the turbo i need to know the fitting size....the one off my old turbo seems to big 1/4" and i've tried 1/8" neither work.....the small hole on the face of the compressor side.. what size is it or do you know a web site i can look at to find out...
Old Nov 4, 2005
HAHAHAHA... +1 f0r j00.. lol.. that was funny..
Old Nov 4, 2005
ajhdragon's Avatar
7thgens official a$$hole
just take your turbo to a race shop and find a fitting that fits.
Old Nov 4, 2005
turboengnr's Avatar
DONT PANIC
Compressor housing is usually an 8mm fine thread 1/4" long bolt.
Exhaust housing is usually an 8mm coarse thread "1/4" long bolt.
hope that helps.
They are a 13mm head.
Try screwing the stock header bolt into the compressor housing. It will most likely screw in.
Old Nov 4, 2005
looking for the size of the hose fitting on the tourbine side of the turbo not the size to mount it..
Old Nov 4, 2005
nismostreets21's Avatar
nismostreets21 can only hope to improve
www.turbocalculator.com
Old Nov 4, 2005
turboengnr's Avatar
DONT PANIC
so the oil feed fitting?
if it is a true garrett center section with journal bearings, it is 1/8" NPT.
Old Nov 5, 2005
no the 90 degree pipe fitting that goes into the tourbine side of the turbo that connects to the waistgate what size that thread is like i said earlier i've tried 1/4 and 1/8" thread both fine and coarse.....they are both to big(obviously the 1/4 was to big if 1/8 was i'm just saying i've tried both)
Old Nov 5, 2005
turboengnr's Avatar
DONT PANIC
yet again, it is a 1/8" NPT (normal pipe thread) fitting. It is not a bolt. So it cannot be coarse or fine thread. It is pipe thread. 1/8"
Old Nov 5, 2005
tried that it seemed too big.........i had a 90 degree fitting that had a 1/4" hose adapter on the other end and a 1/8" thread on the threaded side...but i will try it again..just wanted to know if there was some sort of special thread or not....thanks for all the help
Rodrigo Pizarro
Forced Induction
Sep 6, 2015 03:48 AM
PsshH
Mar 22, 2004 12:03 AM
ImPulse
Engine Swaps
33
Jan 3, 2004 08:05 AM
Catalyst
Engine Swaps
94
Oct 27, 2003 08:57 AM
derty
Engine Swaps
68
Oct 6, 2003 12:45 AM
