Sf t3 flange with t3/t4
Old Nov 1, 2005
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
ok so i have the sf kit with manifold and it came with t3 super 60 turbo, however this time, I would like to use a bigger turbo such as the t3t4 hybrid, I dont care about the downpipe cause I will have it custom made and I will use a actuator with internal wastegate, can the boost junkies tell me if I can simply buy a new turbo such as t3/t4 hybrid and bolt that onto the manifold, will it fit? help pleazs
Old Nov 1, 2005
Pedro Lopes's Avatar
Pedro Lopes is an unknown quantity at this point
Yes it will fit on the manifold. You just have to see if you have space there because the intake housing on the turbo will be much bigger.
Old Nov 1, 2005
turboengnr's Avatar
DONT PANIC
it should fit fine. I only had a problem fitting a t3/t04e housing. All i had to do was shave off some of the aluminum on the housing for it to fit.
The downpipe should be the same.
Old Nov 2, 2005
im stock now! T.T
hey where the hell you been. I been trying to reach you. Either go on aim tonight or ill call you, Im trying to get this done by 2-3 weeks max cause Im going somewhere. Also Im ordering the t3/t4 but it might be the t3/t4e. also Im towing my car from your house back down to la to get it tuned, i got free towing service of up to 100 miles so dont worry on that. I have a new actuator and 5 bolt flang for the downpipe so you can make that 3Inch downpipe onto the catback with that flex pipe. Im just waiting on my tein ss that I ordered should be here by this week all I need now is that new turbo cause i dont want that t3. let me know which one I should get, there are plenty on ebay.. Also you still got those injectors right? I need to get that installed there as well.. Ill give you my suspension, anyways hit me up cause I need to talk to you later.
Old Nov 2, 2005
turboengnr's Avatar
DONT PANIC
you still need to get the plugs for those injectors. I dont have a spare set of those, so you wouldnt be able to run them
Old Nov 2, 2005
im stock now! T.T
what kind of plugs, let me know where to order them and ill order them.. im not familiar with what your talking about, can you just solder the wires.?
Old Nov 2, 2005
turboengnr's Avatar
DONT PANIC
you need the actual plugs that plug into the injector off the SRT4. Our stock plugs will not work.
get the plugs from the SRT4, then we cut off your stock ones, and solder these on in place of them.
Old Nov 3, 2005
iamboo's Avatar
Retired - SoCal FI Mod
i think he's talking about the pigtails that connect to the injectors....
Old Nov 3, 2005
turboengnr's Avatar
DONT PANIC
exactly
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
Jaryn
May 17, 2016 02:52 AM
HondaGuy7
Feb 22, 2016 01:00 PM
PierrePierre
Aug 12, 2015 02:42 PM
7thgensurvivor
Jul 27, 2015 08:23 PM
