install help ---> SF kit in 04
so i just got my SF turbo kit today and mounted(not fully installed) everything.....i read here that its a really easy install but i had a whole bunch of issues (power steering pump in the way of the manifold, i had to cut off 3 fan guards to mount the turbo-intercooler fitting, lower rad hose in the way of intake pipe) and i havent even tried anything with the FMU yet. also on the pipe that goes into the throttlebody there is 2 parts i dont know what to connect to...if anyone has any info for me that might help please let me know. thanx.
Originally Posted by fixeruper
i didnt have that trouble when i installed it on my 04 with that kit, i had to cut the crap out of the bumper though...
im gonna take some pics of it and hopefully you guys can help me out. the kit is new but i bought it from someone on the site so it wasnt shipped directly from SF. all the pipes match up, its parts of the car that are making it tight.
You should have not had to cut your radiator fan shroud. You can loosen the bolts on the turbo housing and rotate the intake side of the turbo. Yes the radiator hose will be pinched. Mine has been this way for about 20,000 miles with no problems.
Originally Posted by yourinmyw0rld
what happen too you? I heard you try to out run the cops? with S2K
i dont have a pics of the install i have a pic of it on my car but i wont be able to load it i can email some one it if they can load it...
ya im gonna get emanage soon, im thinking of installing the kit with only rsx injectors and geting a manual boost controler and keeping the psi at about 4 until i get emanage...that should be safe
Originally Posted by spoonEM
immediately....this thing is a POS!!
Originally Posted by Civic_RedLine
get rid of the sf fmu
That's funny.......i've been running it for 20 months and around 20,000 miles with no problems. I run 8-10 psi daily and i have no blown HG's, spun bearings or smoked pistons. I will agree that it is not the best set-up....but it is effective for those on a budget.
DONT PANIC
Originally Posted by turboengnr
no, you need something to control the injectors.
i would recommend an emanage or an AEM EMS
I answered this question right after you asked it the first time, and 6 post above where you just asked it.
geez..............
ya sorry just realized i already asked...anyways im gonna install the fmu i guess. i have no choice really. only thing im confused about now is the small fitting on the pipe right before the throttle body...theres an electric conection for the fmu, the BOV and another small fitting i dont know what it does.
