Need help! weird boost cut problem...
Old Oct 28, 2005
duck13's Avatar
duck13 is an unknown quantity at this point
d17 with HKS GT-SS at 7 psi... Dastek Unichip fuel management...
I was cruising on the highway at 5th gear... and then I downshifted to 4th gear, it went to about 3500 rpm and I gave a full throttle... the turbo started spooling and when it's about to go into boost, suddenly the BOV went off and I lost the power... and then the check engine light went on right away. but the car didn't stall or anything.
I drove slowly and stop upon a traffic light... when I accelerate on green light, the car felt like losing power and under load (the turbo spooling). when I stop... the car stalled.
when I restart the engine... the engine check light was gone. I went back to the workshop and the guy in the workshop said, it might went overboost. so we set it at 5 psi and did some test runs... nothing happen... the car acted normally.
so what happened there? I'm pretty sure I wasn't even hitting 7 psi when it cuts off...
Old Oct 28, 2005
iamboo's Avatar
Retired - SoCal FI Mod
do you have the missing link check valve installed?
what kind of injectors are you using? What else are you using in your fuel setup besides the Dastek Unichip?
are you using any kind of alcohol injection?
Old Oct 28, 2005
duck13's Avatar
no I don't have missing link check valve installed. It already have a turbo module installed.
sorry I'm new to turbo... my friend who owned a workshop installed it for me.
can't identify the extra injectors but I'm sure it's there.
no alcohol injection too.
Old Oct 28, 2005
Michalo187's Avatar
Abortion Survivor
Get a missing link without the car will stall. The map sensor was ment to read negative(vacuum) not positive(boost) so without the missing link the map reads the positive and thinks the car is messed up. Thats what you should do i think you are good to about 4-5 pounds anything over you need the missing link
Old Oct 29, 2005
duck13's Avatar
the car acts normally now... it never happen again... I got it back up to 7 psi and pushed it hard quite often... weird...
Old Oct 29, 2005
Michalo187's Avatar
Abortion Survivor
I still advise you get the missing link. My car always felt like **** then i got the missing link and everything felt better its a pretty good thing to have and its like 60 bucks. Well who knows what happened that time but good luck and if you have any further questions feel free to pm me
Old Oct 31, 2005
lovinthevtec's Avatar
lovinthevtec is an unknown quantity at this point
M/L or Emanage voltage clamp
Old Oct 31, 2005
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
Missing link!
bowie
Jan 21, 2018 09:29 PM
C-Hamm
Sep 28, 2015 10:31 PM
pilebuck13
Sep 21, 2015 10:45 PM
99BoostedSi
Sep 7, 2015 04:49 PM
junkyardguy
20
Sep 6, 2015 10:07 PM
