BOV, wastegate and boost guage
Old Oct 31, 2005
jamie_civic's Avatar
jamie_civic is an unknown quantity at this point
hey just wanted to make sure im connecting things right.....the boost guage and BOV connect to the vacuum line by a T fitting and the wastegate connects to a nipple on the charge pipe right before the throttle body (a part under boost)?
Old Oct 31, 2005
Michalo187's Avatar
Abortion Survivor
BOV connects to vaccuum boost connects into a t fitting on the intake manifold or a pipe after ther turbo close to the tb. The wastegate connects to the turbo with a vacuum hose
Old Oct 31, 2005
andyman97's Avatar
Turbo Guru
No, that's not right.
Everything reads off of vacuum/boost. Everything is regulated by manifold pressure. Everything should be connected via vacuum line to the intake manifold. The wastegate doesn't control the turbo. All the wastegate does is release excess boost pressure above the desired amount of boost via a spring.
Best bet for all of these people asking these questions is to pick up a vacuum manifold and connect all of your vacuum lines to it.
Old Oct 31, 2005
skipbarber's Avatar
what kind of wastegate? internal or external? how many ports if internal?
Old Oct 31, 2005
its internal...theres a nipple on the turbo right before the air leaves...
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
bowie
Jan 21, 2018 09:29 PM
Munzy
21
Oct 7, 2015 07:48 AM
C-Hamm
Sep 28, 2015 10:31 PM
Dave Brabant
Sep 10, 2015 06:48 PM
