sneak peak of my new setup.....
Old Jan 25, 2006
  #61
turboengnr's Avatar
DONT PANIC
all you would have to do is cut the tape off your wiring harness and re-route wires. I didnt even have to cut any. Then mod an intake pipe to work.
I will even include the modified fuel rail
Price range, i dunno. $250
Old Jan 25, 2006
  #62
Silvernight's Avatar
Silvernight is an unknown quantity at this point
did u see any real HP gains or anything also im not sure if this is true but would there be a real difference between an AUTO and Manual.....of course i have to have the AUTO which doesnt help.....
Old Jan 26, 2006
  #63
turboengnr's Avatar
DONT PANIC
yes, i did feel gains. The biggest gains were at lower RPM, and in vtec.
It seemed to me that it had a bit more low end torque. But the high end power was much better.
Civic_Redline has been in my car, and he admits that it is quite a bit faster than a stock motor. All i have is the DC header and that intake manifold.
Old Jan 26, 2006
  #64
is that 250 shipped....cuz i am just looking for something that will give me that little extra edge....i have headers, injen cai, skunk2 exhaust, AEM pullys thats about it but its not nearly enough....i just wanna be able to hang with some bigger cars...also did u say if it would fit on an auto
Old Jan 26, 2006
  #65
turboengnr's Avatar
DONT PANIC
i would think that it would fit on an auto...
It may actually fit better. On the manuals, the TB sits just above the shifter cables. It does not interfere with anything, but its still about 1/2" above them. The auto doesnt have anything there. I can also send the intake pipe i made to fit it. It is simply a 3" pipe with a 90* bend. Puts the air-filter near the battery.
With the manifold, i will include a set of stock injectors, the modified fuel rail, and the throttle body. But you will need to send me your stock throttle body as trade. The Tb had to be modified to fit. The throttle stop had to be cut off.
But when i take the manifold off, i will also install the bracket to run the cruise control, i will fix some of the small dips in the intake ports that i was too lazy to fill when i originally did it, and i will re-seal the ports with the epoxy that professionals use on ported cylinder heads.
Old Jan 26, 2006
  #66
yuogotown3d's Avatar
yuogotown3d is an unknown quantity at this point
pretty hardcore stuff going on there...cant wait to see the finished project.
Juanb24
Sep 15, 2015 12:39 AM
cdmx
Mar 12, 2003 11:28 PM
Keo
Aug 11, 2002 03:12 PM
2k2civicballer
Jun 23, 2002 10:12 PM
NeonNights
Feb 19, 2002 07:50 AM
