turning the intake on a garrett t3???
Old Oct 19, 2005
black01civic's Avatar
From: Mukwonago, Wisconsin....around the Milwaukee area
black01civic is an unknown quantity at this point
wondering if anyone can tell me how to turn the intake on a garrett t3
Old Oct 19, 2005
performance sys's Avatar
performance sys is an unknown quantity at this point
If you mean clocking the turbo, just loosen the 6 bolts on the back of the compressor housing (compressor housing is the intake side), rotate the housing to wherever you need it, then retighten the bolts.
Old Oct 19, 2005
i've tried that the turbo never spun......do i have to pound on it fairly hard??
Old Oct 19, 2005
turboengnr's Avatar
DONT PANIC
tap on the edge of the housing (outward) with a rubber hammer.
Old Oct 19, 2005
If you have a deadblow hammer, you can hit the turbo compressor housing LIGHTLY to try and knock it loose. Sometimes they get stuck, especially if it is used.
Your best and safest bet though, is to remove all 6 bolts and the little brackets, put the turbo compressor side down on a table (so that no fins are touching the table), have a friend hold down the compressor housing and you pull the turbo free. Be very careful to lift straight up so that you don't damage the fins. Once you get them apart, just align the housing and turbo assembly the way you need it, and reattach the brackets with the 6 bolts.
Old Oct 19, 2005
civic01vtec's Avatar
try doing it when it is mounted in the engine bay......that was a bitch
Old Oct 19, 2005
thanks worked great will be putting a new garrett t3 turbo in my 01 civic ex
Old Oct 19, 2005
turboengnr's Avatar
DONT PANIC
yay.
Allecr3
May 22, 2015 01:24 PM
mrcell24
May 19, 2015 10:02 AM
oqjoi
May 9, 2015 10:31 PM
ORskier
May 7, 2015 04:54 PM
carid
Apr 30, 2015 07:00 AM
