Engine Swap Question
Old Sep 23, 2005
Wolfgang5884's Avatar
My friend has a 1990 Civic Sedan EX. He has a 1997 Civic DX engine available. The engine code for the 97 is D16Y7 I believe. The question is, can he swap the engine with little to no modification? Another question is, can he use his 1990 transmission? Thanks in advance I don't have much time to look for the info myself.
Old Sep 23, 2005
Anyone have an idea???
Old Sep 23, 2005
pimpc's Avatar
pimpc is an unknown quantity at this point
go ask this question or search on honda-tech.com.......they are more into EF, EG, and EK models civics
Old Sep 23, 2005
thx man
Old Sep 23, 2005
doubledeuce2k2's Avatar
i'm thinking you'll have to change from OBD1 to OBD2, but thats a guess based on age of cars.
Old Sep 23, 2005
turboengnr's Avatar
DONT PANIC
what is wrong with the stock motor?
You should be able to swap them, but you will have to use the original head. The 97 has a completely different distributor than his original motor. And to use that dist, you would have to convert it over to OBD-II.
And yes, the tranny will bolt up to the new motor.
Old Sep 24, 2005
his stock motor has over 300k miles and is really becoming a problem. Thanks for the info.
Chronic_issues
May 8, 2015 05:40 PM
zack22490
Apr 29, 2015 03:17 PM
cloudguy
Apr 28, 2015 05:02 AM
shawe90
Apr 14, 2015 07:10 PM
supercivic01
South
Nov 30, 2001 11:27 AM
