RAZ cams add 30hp untuned !!!!
Old Sep 24, 2005
mrDFWmechanic's Avatar
checkin out the clubrsx.com threads and wow cams add 30hp untuned thats simply amazing. makes me wanna do my K20 swap even more http://forums.clubrsx.com/showthread.php?t=283031
Old Sep 24, 2005
Blahman240's Avatar
Touch it... He won't bite, He'll just come at you pretty quick.
Blahman240 is on a distinguished road
damn, they should make one for us now.
Old Sep 24, 2005
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
Good #'s
but all new hp's are on top
low and mid hp's are lower then stock.
Also, does stock rsx-s males only 150whp? looks way to low.
I think all #'s a little optimistic.
Old Sep 24, 2005
Ichiban's Avatar
Ichiban is an unknown quantity at this point
Thats not a K20A2 its a A3 from the Si.
Old Sep 24, 2005
Is it? My bad.
Then, I shuold edit my original post....
I'm not an expert, but does Si k20 turns to 8000 rpm stock?
Old Sep 24, 2005
its the stock ep3 engine with 140,000 miles on it says in the thread at the very top
Old Sep 24, 2005
I saw that,
cant you see the graph?
For the stock run, engine run to about 7700 rpm
With cams the runs were made to about 8200 and 8400 rpms.
Does stock k20 go to 8000?
'Cause I dont think so.
But I might be wrong...
Old Sep 24, 2005
in the guys signature it says he's using Kpro so i'm guessing thats what let him rev to 8400 rpms
Old Sep 24, 2005
Fromt he signature of the guy with RAZ cams:
Engine/Transmission: Raz Cams, custom intake, coated borla header, custom 3" exhaust, intake manifold gasket, MM inserts, K-pro, type-s clutch/flywheel, 6spd tranny + ep3 final drive
I think all these toys come on this motor from the factory...
Indeed, fully stock engine.
Old Sep 24, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
kinda old. I saw that post when I still have my turbo on.
Old Sep 24, 2005
like how old?
from last century??
Old Sep 24, 2005
DelSolid's Avatar
DelSolid is an unknown quantity at this point
He is saying that his K20 with a custom intake, coated borla header, custom 3" exhaust, intake manifold gasket and Hondata K-pro only made 148 HP. Then he put in a set of cams and magically made +30HP!
I would love to see these cams put in a bone stock, healthy K20 and a real back to back comparison made. I have serious doubts about the validity of this test and the tune of the baseline motor.
But, people will no doubt buy them based on this one test.
Old Sep 24, 2005
Thats what I thought of,
same cams, but on the bone stock engone.
hp estimates anyone?
Old Sep 25, 2005
FuzzBeC00L's Avatar
Fuzzy Boy
Cams won't do **** for the d17buddy
ricer_em2
May 11, 2016 08:09 PM
Munzy
21
Oct 7, 2015 07:48 AM
Islesfan
Sep 29, 2015 03:42 AM
General DIY
Sep 25, 2015 08:02 PM
OptimisticWay
Sep 18, 2015 09:37 PM
