GSR axles work with K20 swap !!!!!
Old Sep 22, 2005
mrDFWmechanic's Avatar
check it our for yourself ... http://www.honda-tech.com/zerothread?id=1379830
Old Sep 22, 2005
Rufus's Avatar
Provacative
Old Sep 22, 2005
skipbarber's Avatar
good to know.
Old Sep 22, 2005
fastest_ex's Avatar
fastest_ex is an unknown quantity at this point
we already know that but in some cases u still have to send the axles to a machine shop to be extended
Old Sep 22, 2005
ajhdragon's Avatar
7thgens official a$$hole
guess what 93-96 dodge intrepid axels work on an H22 swap into a crx
Old Sep 22, 2005
kornsined's Avatar
also the base rsx engine which many said woudn't fit
Old Sep 22, 2005
Rufus's Avatar
Chevelle rearends work in CRX swaps with the G24 from the 99-01 GMC Envoy
Old Sep 22, 2005
HondaLuver's Avatar
Its a celebration bitches!
hummm
Old Sep 22, 2005
Rufus's Avatar
Originally Posted by aznboysrfr
um ... ok. did you want some reward for it?
No need to be an assclown. Its a good FYI
Old Sep 23, 2005
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
gsr axles do fit fine for the swap and YES hasport does and have mention it on there website and at one point is was said so in the hasport mount install insturctions. the problem with them which has already been said is that the axle is too short. so if you even try to race with gsr axles in your swap be prepared to put in some new ones because its going to snap at the tracks or whereever you decide to race. this has been asked numerous times before so dont make such a big deal about it.
Old Sep 23, 2005
i had no idea that gsr axles would work on a K20 swap so i posted it so other members would read this too
Old Sep 23, 2005
exturbo6's Avatar
r the k swaps going down in price yet?
Old Sep 23, 2005
HondaLuver's Avatar
nope... i would just get si axles... works fine, no ****ing around...
Old Sep 23, 2005
C2i0v0i1C's Avatar
SuperMODrizd
whether it was said here or there, its new to me and i dont recall seeing a thread about it in the recent month at least. so stop the bitchin
Old Sep 23, 2005
C2i0v0i1C's Avatar
SuperMODrizd
and ur were right to do so
Old Sep 24, 2005
nobodys bitchin about it.. basically someone thought they found out something that nobody else has tried or knew.. posted his/her findings and then this is the result of his findings...
then of course we come to the obvious when people say use the search button.. and like all people instead of giving a helping hand they just leave it at that..
so.. when using the search button here is what i found and many others of the same thing that has been covered...
http://www.7thgencivic.com/forums/sh...=k20+gsr+axles
and here is a post directly from brian g from hasport
Old Sep 24, 2005
C2i0v0i1C's Avatar
SuperMODrizd
the brian G link, is from 2003, things might have changed
Old Sep 24, 2005
Rufus's Avatar
PM him. His name on here is none other than BrianG
Old Sep 25, 2005
well i can for a fact tell you it hasnt changed as of july 2005....because i was going to do the same when i did the swap and called hasport and they specifically said not to use the gsr and you take your own risk of damaging your own engine components.
Old Oct 7, 2005
1llmatic's Avatar
1llmatic will become famous soon enough
the gsr axles work with the rsx inner boot.
without the inner boot the axles will pop out...that was my problem initially.
the gsr axles are a little short and yes i snapped an axle my 1st day at the track 5000rpm launch on street tires.
Axlesystem.com has upgraded axles for the 7thgen now after developing axles for my car.
Jigee
May 9, 2015 11:18 AM
Chronic_issues
May 8, 2015 05:40 PM
mikevtec
May 3, 2015 01:36 PM
ORskier
May 3, 2015 12:54 PM
TaiChi
Dec 17, 2001 09:09 PM
