DIY: K20/K24 into 2001+ Civic **Updated 4/20/2008**
Old 12-17-2007
  #181
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
Re: DIY: K20/K24 into 2001+ Civic **Updated 11/24/2007**
Originally Posted by EMK20a2
I just bought fuel line at autozone and used small hose clamps to hold it on.
ditto...
or you can get some steel braided lines and do that
Old 12-19-2007
  #182
civiclowlife's Avatar
civiclowlife is an unknown quantity at this point
how about tsx K24A2 is that a good swap Im finding them in my area for 2k just the engine
Old 12-19-2007
  #183
EMK20a2's Avatar
EMK20a2 will become famous soon enoughEMK20a2 will become famous soon enough
that is a good swap, I am honestly not sure about the availability of engine mounts though. I think the big difference is the tranny mounts with that swap, someone correct me if I am wrong.
Old 12-20-2007
  #184
streetthrowback's Avatar
streetthrowback should not be trusted
yo x looking at the o2 sensor DIY it looks like ur wiring the relay to the ecu, how do you wiring the o2 sensor, do u think u can take a pic of your 02 sensor and how you wired it up, it would really help thanks
Old 12-21-2007
  #185
its not hard to understand.. what part u dont understand.. its pretty much straight forward...
its like wire A goes to wire B... plain and simple... try reading it again but take it in steps
for me to take pics i would have to tear apart my whole harness...
on a side note if your note good or never done complicated wiring i suggest you have someone that does help you out
Old 12-21-2007
  #186
cinaibur's Avatar
cinaibur is just really nicecinaibur is just really nicecinaibur is just really nicecinaibur is just really nicecinaibur is just really nice
yo xproductionz. I PM'd you but got no reply.
Old 12-21-2007
  #187
Mr_Plenty's Avatar
Mr_Plenty is a jewel in the roughMr_Plenty is a jewel in the roughMr_Plenty is a jewel in the rough
k24a2 is a good swap but you'd have to change tranny because theirs arent any mounts currently for the tranny in our chassis. the head is a little bit more restricted than a type s head aswell. If we had the tranny mounts it would be the best swap imo. the type r gears are 2 short for me....when it comes to drag racing that is. Other than that i feel thats its best to just swap a type s engine in the car and then later upgrade to the 2.4l bottom end. K-series = expensive.
Old 12-21-2007
  #188
EMK20a2's Avatar
Those 2.4 frank swaps are amazing especially with a bit of NA building, 250-270+whp is very realistic with a setup like that.
Old 12-22-2007
  #189
where can I find engine mounts other than hasport?
Old 12-22-2007
  #190
and what transmission would bolt on to a tsx?
Old 12-22-2007
  #191
EMK20a2's Avatar
any of the K series trannies. The ones that you can get the mounts for would be the k20a3 (EP3 5spd), K20a2 (RSX type S 6 speed), and a K20a (Integra type R 6 speed). Any of the newer Si/type S trannies will work, but the speed sensor is different, so it is difficult to get the speedo to work with this tranny. I would steer clear of any of the 05-06 type S or Si trannies due to the difficulty.
Old 12-23-2007
  #192
TURTLEonK
Nameless's Avatar
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
^ Its super easy to get the 05-06 Transmission to work, you just tap one wire from the ECU (E26 on 05 - 06 ECUs) to the C101 (On the civic side interior, Pin 6 Blu/Wht) connector and thats it... you have Speedo. I am running a complete k20z1 with tranny and wire harness and everything works.
Old 12-24-2007
  #193
EMK20a2's Avatar
Good to know, I never had the need to research, I just have heard how difficult it was. Do you need the 05-06 ECU?? I know that you can use Kpro for something related to the speed sensor, maybe that is for getting the older ECUs to work with the newer trannies.
The nice things about those trannies is you can get them fairly cheap.
Old 12-24-2007
  #194
TURTLEonK
Nameless's Avatar
^ 05-06 transmission is way better than the 02-04 just because of the 4.7FD, and less problems all together(like grinding etc)
Older ECUs work only if they are KPRO'd, and you have the 05-06 Adapter harness. It takes a little bit of rewiring but not too hard if you have access to wiring schematics.
Old 12-25-2007
  #195
When is someone going to wright a book, like they used too.
Old 12-25-2007
  #196
this is the closest u will get to one... lol.. i could write one... but the problem is that it would be outdated once it was released
Old 12-25-2007
  #197
EMK20a2's Avatar
I actually prefer the longer gearing, atleast for what I want from my car.
Old 12-25-2007
  #198
Yaj00003's Avatar
Yaj00003 is an unknown quantity at this point
Hey guys well when I brought the K20a3 it doesnt have any motor or transmission mount well which mount do I need from the K20a3...well part number is also good too...well thanks for the help last time xp...
Old 12-25-2007
  #199
EMK20a2's Avatar
You need the subframe and I thnk the front engine mount, it has been so long I can't remember which ones are OEM and which ones are from the kit.
Old 12-25-2007
  #200
u dont need any oem mounts.. just get the hasport kit and your done.. the only thing you will need is the rear tranny mount BRACKET
Old 12-25-2007
  #201
EMK20a2's Avatar
I don't think I got all of the Mounts with my kit?? Maybe I did though, like I said it has been a while.
Old 12-27-2007
  #202
Yaj00003's Avatar
Which rear mount tranny is that...I guess I have to take a pic of my motor and my tranny than....maybe that will help alot more...
Old 12-27-2007
  #203
u need the rear BRACKET... the hasport kit a;lready comes with the mount.. you just need the BRACKET
Old 12-29-2007
  #204
NastyNunez's Avatar
NastyNunez is an unknown quantity at this point
X, My swap is finnaly done. Youre guide helped a bunch, but you left out the little things! BTW What year was your em2?
Old 12-29-2007
  #205
lol.. my year is 2001.. but i have done 22 swaps in the em2 chassis and counting...
the little stuff i left out intentionally... most of it was common sense and doesnt take a mad scientists to figure it out.. especially if you work on cars then you know where the small stuff goes.. but like i would tell everyone that asks me about the swap... if you never done anytype of extensive motorwork or swaps then this guide is just a basics on how to get the motor in and out and so forth.. lol.. example would be like the brake booster line from the master cylinder... theres only one place for it to go on the manifold.. lol..
Old 12-29-2007
  #206
kcari's Avatar
have you ever done an automatic transmission swap? type s automatic?
Old 12-29-2007
  #207
NastyNunez's Avatar
The stock d17 shifter cables are shorter then the k20a2 cables. I knew i should have taken a picture of them for people to see. Little things like that is what im talking about. Maybe theres a trick to making the stock ones work? Who knows @@ As soon as i put on the k20 cables, it shifted perfect.
Old 12-30-2007
  #208
Yaj00003's Avatar
xproductionz do I need a ac compressor just to put in the alternator cuz it also doesnt come with it...and I think there like a front mount that on it too right...from what I see and research there only 3 mounting that I need the passenger front side, rear, and trans mount right....?
Old 12-30-2007
  #209
uhhhhumm... is that the little things you were talking about that was missing from the DIY.... welllll.. hate to burst your bubble but in my DIY it does say you need the shifter cables from the RSX..
the only way ur gona get stock ones to work is the extend the length of the d17 cables... i tried... been there done that... trust me.. failed miserably... it actually costed me more to attempt to try and make my cables longer versus buying some new/used k20 ones.. i tried taking short cuts and finding cheaper routes to do the swap..
u only need 3.. driver.. passenger and rear mount... thats what hasport kit comes with..
you got 2 options with the a/c compressor.. you can get rid of the compressor but you gotta run a custom length belt. OR... you can put in the compressor and run a factory belt... ur choice.. hoever i do have a compressor for sale if you need one
Old 12-30-2007
  #210
they dont make a type-s in automatic... however they do make a base rsx
i have done one.. actually costed more to do the swap than a manual.. but problem with that is you cant get or use kpro with an automatic... basically ur just doing the swap for like an additional 50-60 hp and cant really do any performance related things to it.. i mean u can but not as much as the kpro guys..
honestly ur better off doing the conversion to 5/6 speed and learning how to drive stick
Quick Reply: DIY: K20/K24 into 2001+ Civic **Updated 4/20/2008**
