Pistons, rods, sleeving?
Old Aug 29, 2005
Hwoody77's Avatar
Hwoody77 can only hope to improve
Ok, I have pistons and rods, do you think it is worth the trouble sleeving? How much boost can I run with just pistons and rods? How much if I sleeve? Thanks!
Old Aug 29, 2005
HyaBoosta's Avatar
sleeving is def. a good investment. it will allow alot more boost, but our lack of fuel and tranny and axels will have to be adressed after. It's a good insurance policy for your investment. Would you want to go thru the trouble of having the pistons and rods installed only to crack a sleeve and chance having to buy new pistons and rods?
Old Aug 29, 2005
CLeeNx04CiVic's Avatar
CLeeNx04CiVic has a little shameless behaviour in the past
^^I agree...just save up some money and definately sleeve it...my 91 DA ls-vtec is sleeved...its a very good feeling knowing i can go hard anytime without worrying about cracking a sleeve know what i mean...u wont regret it
Old Aug 29, 2005
Havok2k1's Avatar
Wicked Pissah Admin
do it right the first time
sleeve it
Old Aug 29, 2005
C2i0v0i1C's Avatar
SuperMODrizd
dont waste ur time tearing a motor apart and rebuilding with everything brand new and not finish the job by sleeving
Old Aug 29, 2005
civic01vtec's Avatar
agreed with everyone else.......do it right the first time.
Old Aug 29, 2005
allmotor's Avatar
nor cal 7thgens
alot of people on honda-tech have ran over 300 hp on d16's without sleeves so u could do it but if u got the mtr apart might as well invest in it
Old Aug 29, 2005
Michalo187's Avatar
Abortion Survivor
I am trying the kms blockguard cheap way and a lot of people say its not worth it but so far i think its a good investment
Old Aug 30, 2005
Blahman240's Avatar
Touch it... He won't bite, He'll just come at you pretty quick.
Blahman240 is on a distinguished road
d16's and d17's are totally different. A d17 is a weaker block.
Old Aug 30, 2005
andyman97's Avatar
Turbo Guru
You can get away with around 350 whp without sleeves. Anything close to or over 400, you should get sleeves. I haven't known of anyone with a d17 that cracked a sleeve from too much power.
Old Aug 30, 2005
Hwoody77's Avatar
Lol there aren't many D17's making that many power period.
Old Aug 30, 2005
HyaBoosta's Avatar
I think our weak points are the tranny and the fuel system. we need a new rail to fit the right size injectors in there to support that kind of power!
Old Aug 30, 2005
diskreet's Avatar
i agree... sleeving is good. but the D17 tranny is relatively weak even with an overhaul kit. plus you gotta consider if you want to up boost your stock head is going to need some work. P&P is pretty much a must as an econobox like this isnt designed for great air flow! get new cams, especially since crower finally delivered on the D17, and obviously springs, valves, and retainers. grab bigger injectors, like off an RSX-S or even bigger.
then you should be good to go.
Old Aug 30, 2005
ren808's Avatar
ren808 is on a distinguished road
would the crank shaft have to be replaced...are there any complete kits for sleeving? :/
Old Aug 30, 2005
DrOpPeD2k2CiViC's Avatar
DrOpPeD2k2CiViC is an unknown quantity at this point
Dont waste your money on sleeving it you can get in the 300hp with stock sleeves aslong as you have a GOOD tune on it. Its all about the tune whether or not things are gonna be reliable or not
Old Aug 30, 2005
turboengnr's Avatar
DONT PANIC
Where did you get that information?
I have spent hours on the phone with Darton. The only thing they saw that was weak on the block was the casting at the bottom of the cylinders. They said that if you were to keep the cylinders from walking (by use of a block guard), then you would be able to run "15-20 psi of boost" (this is not a "daily number", he said 15 daily, 20 track).
Old Aug 30, 2005
HyaBoosta's Avatar
You can go pretty high before having to touch the head. only think to be afraid of is valve float. There are no sleeving kits as of now but any machine shop could do it. I suggest either Benson or Darton sleeves. really tough to trust a local shop. I plan on having mine don next month. Then all I have to solve is the injector problem then im going to aim to break the 300whp mark
Old Aug 30, 2005
supermex's Avatar
supermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to all
Rebuild an engine for boost or racing and not doing slevees,
is like buying a house in Lousiana and not buying flood insurance.
Old Aug 30, 2005
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
^^ or Florida for that matter..
Old Aug 30, 2005
turboengnr's Avatar
DONT PANIC
It can be done without sleeves.
But i sleeved my motor.
Old Aug 31, 2005
civicskater's Avatar
Chicks dig my scent
i should have sleeved when i did my pistons/rods/headgasket, but i didnt have the $$ or time then. My motor is fine without the sleeves but it would have been a good investment
Old Aug 31, 2005
Blahman240's Avatar
It would be a good mod, also help for higher boost.
Tedverseti
Apr 23, 2020 01:45 PM
Tedverseti
Sep 29, 2015 05:41 PM
rovafa2002
Sep 28, 2015 06:57 PM
Bruce2
Sep 27, 2015 08:45 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
