K24 Engine w/ K20a3 Tranny
Old Aug 16, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
Would their be a problem using an a3 tranny on a K24 engine. I was talking to a shop about doing a k24 swap. He suggest me on using an a3 tranny, because it is cheaper, better gearing for k24, and it will balance everything out (i am not too sure what he meant).
Any POSITIVE comment is welcome.
Old Aug 16, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
nope ... no problem
Old Aug 16, 2005
turboengnr's Avatar
DONT PANIC
i would still opt for the 6th gear. from my experience in my buddies Si, the 5th gear is very low. He got horrible gas mileage compared to a type s
Old Aug 16, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
another question. By swapping a k24 w/ a3 tranny. Does it enable for me to have ac and ps???
(Right now I have no ac, due to my dam intercooler piping and downpipe. It is hot like a bitc* this summer and I can't see a $hit when raining. etc..........)
I think a, a2 and a3 enable us to have ac and ps right?
Old Aug 16, 2005
HondaLuver's Avatar
Its a celebration bitches!
yea, you have to use si ac lines, your stock compressor radiator... all the k series compressors fit all motors.. so a k20a will fit on a k24...
i suggest using the A2 tranny because of the shorter gears and since you can not rev very high everytime you shift, you will shift out of vtec... so it will really suck.. which k24 are you thinking of using, and i also suggest to use kpro...
Old Aug 16, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
will be using a k24 out of the tsx. Do I really need to get kpro right away? I am planning on getting kpro, but that is down the line....
Old Aug 16, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
since I'm pretty sure you have to use a k20a2 ecu, you need to get kpro.
your custom title says k20 soon ... you should change that, shouldn't you? ;P
Old Aug 16, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
Not quite, because i havn't decided on which engine I am swapping. I could change it to "K Series SOOOON"" though.
What is the price on this swap, anybody know? K24 TSX + K20a3 Tranny + Misc K20a2 parts + labor = ???? (I got motor mounts already). I got a quote from a shop which is pretty good, but I just want too see what others are paying.
Old Aug 16, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
I don't know about other people, but this is what I paid (am paying):
K20a front clip: $5700 (including customs, shipping to my shop)
K20a3 axles: $200
modification to the exhaust: ?
oem dc5-r header/cat: $300 (incase my clip doesn't come with one)
ep3 Fluidyne radiator: $500 shipped
oem ep3 radiator hoses: $12
ep3 aem v2: $130 shipped
nextgear img: $60 shipped
quaife lsd: $900 shipped
labor: $250
misc. parts (harness, differential bearings, etc): $150-ish
hasport mounts: $475 shipped
my total: $8677
a bare dc5r swap would probably cost about $7000-7500 ... you really don't need to get a fluidyne radiator, quaife lsd or any other bling items that I got.
a K20a2 swap will be about $2000 cheaper that that
Old Aug 16, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
K20a3 axles: $200
labor: $250
my total: $8677
Are you doing the swap urself or having someone do it?
Old Aug 16, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
drivetofast is gonna do it ... he's actually charging me 150 for labor ... the shop owner is charging me 100 to use his lift for a day, so I just combined those
Old Aug 16, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
$150 for labor . Great a$$ deal. My shop quote me $6k for everything, on the tsx swap.
Old Aug 16, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
yeah, we've been buddies for like 5 years now ... he always hooks me up ...
hm ... tsx swap, hmm? ... iirc, you'll have to use the k20a2 ecu, kpro, k20 intake mani + tb ... k20 subframe, k20a3 axles (if u want 4 lug) ... oh yeah, lots and lots of tylenol.
Old Aug 16, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
I am not tooo sure if he included k-pro or not. K-pro alone is 1k already. Is it possbile to run the a2 ecu and leave it untune, or should I call back and ask what his going to use as tunning?
He did a k20a2 b4 and 1 tsx swap.
Old Aug 16, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
eh, I wouldn't run a plain k20a2 ecu ... rev limiter is at 8k, which would make your motor turn into scrap metal. I'm sure the timing is very different as well ... the compression and cams are almost the same though ... I have no idea haha
kpro includes a base tsx map ... so you should be able to run that until you get a tune
I think you should call him up and ask him what kind of ecu he used for the other tsx swap ... if they got kpro, then I would suggest that you get kpro as well
Old Aug 16, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
^^^ where did u get ur front clip/engine from??? He told me for an a2 swap is 8k-8.5k.
If you said a2 is 2k cheaper, would it be somewhere around $6.6k-7k?
Maybe I will just get the engine and let the shop install it (it is 1k to drop it in).
Old Aug 16, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
Just called the shop. He will be sending the off the ec to Hondata for reflash w/ a TSX base map.
Old Aug 16, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
a2 would be probably be around $6000 if you don't DIY
you can find an a2 motor easily ... junkyard ... car-parts.com ... k20a.org has some every so often and also check clubrsx. you can easily get it for about 3500 for a full/near full swap ... there's one right now in central cali on k20a.org for 3500 + s/h I think
swap - 3500
subframe - 300
axles - 200
mounts - 475
ep3 radiator - 200-ish
misc. parts - 200 or so
k20a2 oem header - 200
that's almost $5k ... if you can get all that, you can pay a shop to swap for like $1k ... or you can rent a cherry picker and attempt to DIY. If you shop around and if you're patient, you can find parts for cheaper than that. if you don't know how to do it, wiring will kill ya
any way you look at it, a k20a2 swap should NOT be more than $6750-ish ... if it's more than that, you've paid too much
Old Aug 16, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
I mean I found some gooddeal at k20.org, but I am scared it is hot off the street.
Plus you have to get ur car and key to honda and they will run a check on it to the flash. if it is hot, I am fuc*ed.
Old Aug 16, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
I believe www.hmotorsonline.com have started stocking K20a2 swaps ... they are expensive as hell, but they are also easily THE most trusted and reputable shop period. you can also ask them to take a pic of the VIN plate on block ... then you can call a police station and have them check it ... there are also some vin # checker websites on the net I believe
if you have a friend that works for honda or acura (hehe ... drivetofast), then he can easily reflash your key for you (for free)
if you have kpro, you don't need to reflash it ... just turn off your immobilizer
Old Aug 16, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
hondaluver - pm'ed you some question.
Old Aug 16, 2005
ajhdragon's Avatar
7thgens official a$$hole
shouldn't be a probalem at all, and if your looking to sell the turbo setup, hit me up when your ready.
Old Aug 16, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
Turbo kit is up 4sale.
http://www.7thgencivic.com/forums/sh...d.php?t=224231
If you are local, I will cut you a deal.
Old Aug 16, 2005
ajhdragon's Avatar
^^posted about it and good luck with your swap. can't wait to see it locally.
Old Aug 19, 2005
HondaLuver's Avatar
humm
Old Aug 19, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
mistahlorax13
21
Nov 18, 2015 12:47 PM
speedlever
Sep 24, 2015 07:18 PM
Kyle Cargazm
Jul 16, 2015 02:06 PM
JoeB16
61
Oct 16, 2003 07:58 PM
wh3nw0rdsesc4pe
Sep 22, 2002 02:58 PM
