k20a3 --> k20a2?
Old Aug 8, 2005
mdb_foxmx's Avatar
mdb_foxmx is an unknown quantity at this point
k20a3 --> k20a2?
Hey, just wondering if this could be done...I would think a k20a3 swap would be a heck of a lot cheaper than a k20a2, but you'd really miss that extra 40 or so hp. But, couldn't you swap the a3 in, and then pick up an a2 head from a junker and swap them out? I mean, there's got to be a way to do that, with a few mods to the head and such, right? Anyone already done this? Or has this been figured out already in a magazine I don't get?
thanks in advance.
edit...wow.. just noticed my point total is 6666...creepy.
Old Aug 8, 2005
Jrfish007's Avatar
I beleive Sport Compact Car did this swap in a Civic Si last year.
Old Aug 8, 2005
Jrfish007's Avatar
OKay, they took it a step further, they used a K24 block, and put K20A2 heads on it. Here ya go,
http://sportcompactcarweb.com/tech/0406scc_hybrid/
Old Aug 8, 2005
HondaLuver's Avatar
Its a celebration bitches!
k24a2 >k20a2>k20a3
Old Aug 8, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
^ werd.
even with a k20a2 head on a k20a3 block, you won't make as much power. K20a3 compression is 9.6:1 (iirc) while the k20a2 has 11.0:1 compression.
from what I've read, the k20a3 crank is balanced and the k20a2 crank is balanced and counterbalanced ... I've also read the k20a2 block has oil squirters while the a3 does not.
I wouldn't go with an a3 ... but that's just me ;P
Old Aug 8, 2005
mdb_foxmx's Avatar
yeah, you're all probably right...how much does a k24 run these days?
edit: actually...nah. k24 would be nice, but I like the k20a2. It's pretty damn sporty.
Old Aug 8, 2005
ImportRacer2123's Avatar
K20 Member
you can do the k20a3 swap and either get a custom cam regrind from a company called razz. someone bought it from them and gained 30whp untuned. and he had 110k on his a3. another option would be get a 6 speed tranny, a2 head, crank, pistons and rods.
Old Aug 8, 2005
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
a3 is better for turbo: low compression and gearing is longer, chep to replave if fvcked up.
just my $1000000000000 and $0.02
Old Aug 8, 2005
HondaLuver's Avatar
k24a4 is also, 9.7 compression
Old Aug 8, 2005
fastest_ex's Avatar
fastest_ex is an unknown quantity at this point
the k20a3 block can't handle high rev"s of k20a2 head. do it right the first time go for k20a2...
Old Aug 9, 2005
Jrfish007's Avatar
Nah.. go K24A4 with a K20A2 head and boost... That'll move your civic
Old Aug 9, 2005
Vantage's Avatar
Vantage should not be trusted
k20a3 only makes 125.8 whp... thats nearly 10 hp less than a b16a's 138whp. k20a3 is a terrible engine IMO...
Also both are rated at 160 crank HP.
Old Aug 9, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
^ agreed.
drivetofast's k20a3 with aem cai, hondata img, stock header/cat, greddy evo2 exhaust made 126 whp ... same setup with dc race header made 141 whp.
k20a3 = crappy.
Jodster
Engine Swaps
35
Oct 22, 2003 10:16 AM
vivid_BLUE
Bolt-on Engine Performance
Sep 29, 2003 02:57 AM
hothondacivic02
Jul 16, 2003 05:33 PM
Player1
Jun 14, 2003 04:31 AM
NoBottleJustThrottle
North Cali
16
Mar 22, 2003 06:13 PM
