Shaft PLay
Old Aug 3, 2005
exturbo6's Avatar
Shaft PLay
How do you get rid of shaft play?
Old Aug 3, 2005
andyman97's Avatar
Turbo Guru
Take it to a professional that knows how to repair and rebuild turbochargers. If the wheel isn't rubbing the housing, you should be fine.
Old Aug 3, 2005
exturbo6's Avatar
k. i think its fine. it just moves a very very lil.
Old Aug 3, 2005
civic01vtec's Avatar
exactly.....it is something that you can't DIY
Old Aug 3, 2005
andyman97's Avatar
Turbo Guru
That's normal. I had a turbo checked out by a turbo shop one time and I'm not sure what they did to it, but after about 20 miles of driving, the wheel hit the housing after I got it back from them. I was pissed. They blamed something else, go figure.
Old Aug 3, 2005
exturbo6's Avatar
dam well that sucks. im at the point where i do not know who to trust with my car. everyone tells me they know what they are doing and just mess **** up and cant make it work right. so im on a mission to find a good place.
BUt i have very lil play. does it matter?
Old Aug 3, 2005
Narfcake's Avatar
Narfcake is an unknown quantity at this point
Some turbos will have more shaft play than others. T3 and larger Garretts will usually have some; T25 shouldn't have much at all. Misubishi turbos shouldn't have much, if any, either.
If it's not consuming much oil, then live with it. Otherwise, although it is possible to DIY, it's even easier to screw it up ... and extracting broken parts out of a turbo housing isn't fun.
-- Kane
Old Aug 3, 2005
andyman97's Avatar
Turbo Guru
No, it should be fine, I wouldn't wory about it.
mistahlorax13
21
Nov 18, 2015 12:47 PM
rovafa2002
Sep 28, 2015 06:57 PM
speedlever
Sep 24, 2015 07:18 PM
pilebuck13
Sep 21, 2015 10:45 PM
Jrosa
Sep 14, 2015 08:24 PM
