how much will the ecu try to adjust the fuel while in closed loop
Old Sep 22, 2005
  #31
leonhsieh's Avatar
leonhsieh is an unknown quantity at this point
esc1 will make ecu goes into open loop when it senses postive pressure, which will prevent ecu to adjust fuel under boost. you still have to tune your close loop(not in boost) to desired a/f ratio at to prevent ecu touch your STFT.
Old Sep 27, 2005
  #32
GLi4dr's Avatar
GLi4dr is an unknown quantity at this point
Mad props to 'turboengnr'!
So...after reading about eManage "not" working right...does this lil` trick fix the problem?? ie. If the time is spent to set up your throttle trims and then tune and WOT, things should be sweet and the factory ECU will leave it alone and wont go changing things yeah?? Or should you still keep tabs on it every now and then to make sure its still where you last left it??
One more quick thing...
Check list for tuning:
OBDII Scanner
WideBand
Laptop with EMS Software
Is that all that is needed??
Again, huge thnx for this info
-BEN
Old Sep 27, 2005
  #33
mclean987's Avatar
mclean987 is an unknown quantity at this point
kool
Old Sep 27, 2005
  #34
turboengnr's Avatar
DONT PANIC
the biggest thing with the emanage is getting it to idle correctly with large injectors, without throwing a check engine light.
Old Sep 27, 2005
  #35
dezod's Avatar
7thgen Power Maker
Define large?
We did it with the RSX injectors.
Old Sep 27, 2005
  #36
TheSmuggler's Avatar
600cc+ lol
Old Sep 27, 2005
  #37
tfnaaf's Avatar
BLDNPSI Mod
mine idled perfect with just the cc correction on RSX injectors
Old Sep 27, 2005
  #38
ncirom2003's Avatar
how much is this "wideband" you speak of and exactly what is it?
also what this esc1 you guys are talking about? sounds good
Old Sep 27, 2005
  #39
tfnaaf's Avatar
BLDNPSI Mod
Here is the wideband i have, mine cost me $450-500 ish, but you can get others for much lesshttp://www.plxdevices.com/M-Series_l...roductinfo.htm
Here is what a esc1 is
Description:
The ESC1 EGO Signal Conditioner alters the signal from EGO sensors under boost conditions. It may be used in either single or dual EGO sensor applications. Under vacuum conditions it outputs a signal which is identical to the EGO signals that appear at the input. Under boost, it outputs an internally generated signal to allow open loop operation.
The ESC1 is especially useful for forced induction conversions where a supercharger or turbocharger is fitted to an engine which is normally naturally aspirated. In the vacuum region of operation the ECU operates in its normal closed loop mode of operation. Under boost, the ECU transitions into an open loop mode and maintains its internal mapping tables.
The ESC1 allows the conversion to forced induction on engines with modern fuel injection including those with OBDII on-board diagnostics. The stock ECU programming may be used without activation of fault codes under boost.
http://www.splitsec.com/products/esc1/esc1ds.htm
Old Nov 4, 2005
  #40
DaRk_MauL's Avatar
DaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of light
this is also a nice wideband.
http://www.zeitronix.com/Products/zt2/zt2.htm
Old Nov 4, 2005
  #41
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
now im scared to use emanage, will the computer try to adjust it daily? and if so what do i do to stop it..
Old Nov 4, 2005
  #42
tfnaaf's Avatar
BLDNPSI Mod
Not daily, every second or less , the key is to get it set properly for the conditions your running
Old Nov 4, 2005
  #43
turboengnr's Avatar
DONT PANIC
dont be scared. Just follow my little guide and it will be fine.
Old Nov 4, 2005
  #44
im stock now! T.T
well you can tell me what to worry about and what not when I get there...
Old Nov 4, 2005
  #45
turboengnr's Avatar
DONT PANIC
yea.
the 25th may be our date
Old Nov 4, 2005
  #46
do you know if there is a map for startup a/f? cause ever since the exhaust went on (along with I/H pnp head), my car is having trouble keeping steady idle right when starting it. It just bogs and shakes like the rpm is too low. then once it warms up a bit, everything is normal.
Old Nov 4, 2005
  #47
turboengnr's Avatar
DONT PANIC
i believe it runs its default fuel map. Same as if you were to unplug the o2 sensors. Somewhat like limp mode.
Old Nov 5, 2005
  #48
DaRk_MauL's Avatar
starting a car is done in open loop because of the o2 sensor nog being
hot enough for the chemical reaction to give a right value.actualy it wont
know how much mixtures because it in open loop? how dos this work than
to idle the car right if it doesnt work by the fuel trim in closed loop?
Old Nov 5, 2005
  #49
im stock now! T.T
yea.
i was hoping the 18th
Supramk3
Jun 11, 2015 11:13 AM
Supramk3
May 11, 2015 07:55 PM
McD
Apr 22, 2015 05:28 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
CiviCKiD
Jan 1, 2002 08:02 PM
