Bit curious???
Old Jul 19, 2005
jackburton's Avatar
jackburton will become famous soon enoughjackburton will become famous soon enough
Bit curious???
Now people are saying that you can get a TSX engine cheaper than k20A2, and do a frankenstein swap for about the same if not cheaper than the K20A2 swap.
If this is true why the are most of the people on here who are swapped have k20a2's and not the tsx or frankenstein swap????????
You get more power from both, and more potential power, right?????
So again why are the majority of you out there who are swapped have the k20A2???????????
Old Jul 19, 2005
doubledeuce2k2's Avatar
little things add up. so you found a tsx full swap. wonderful! but you can't use most of it. rsx-s tranny, throttle body, intake manifold, i believe axles (could be wrong) but you see the direction i'm heading. frankenstein means you need to find a complete head. and now you can't use the ECU so you have to pick up a rsx-s ecu and have k-pro put in. it is i'm sure a LOT of work and time to get everything together. not cheaper any way i see it
Old Jul 19, 2005
jackburton's Avatar
I did not think it sounded right, thats why i was curious.
Old Jul 19, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
http://www.7thgencivic.com/forums/sh...29#post3214729
Old Jul 19, 2005
Havok2k1's Avatar
Wicked Pissah Admin
Cmon man, stop posting stuff thats already here. Start looking for answers in threads that exist for yourself instead of taking the easy way out and asking them again....
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
mrohitredd
40
Sep 9, 2017 12:03 PM
thaler4cuse
Sep 7, 2015 08:25 PM
Dakota21601
Aug 18, 2015 08:41 PM
Strycker
Aug 18, 2015 02:25 PM
