Mex's e-manage install / tuning problems continue...
Old Aug 2, 2005
  #61
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
does that only affect VTEC though?
Old Aug 2, 2005
  #62
andyman97's Avatar
Turbo Guru
Yeah, but it could affect other things also. Dude, I would start from scratch if you're having that much trouble. Don't boost it or run it hard. Reset everything on the emanage as though you're running stock. Rewire everything. Odds are your wiring is off somewhere.
Old Sep 10, 2005
  #63
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
bumping this thread instead of creating a new problem..
i installed the ignition harness today.. i followed andyman's DIY on the install of all harnesses. i checked over my wires at least 6 times made sure everything was connected properly.. the car will not start unless i kinda pop the clutch during start, it won't start normally at all.
i was throwing a misfire code on cyl 2 so i checked the wiring and it turned out to be ok. we swapped the sparkplug from cyl 1 to cyl 2 to see if it was fouled. we started the car again and it still through a #2 cyl code.
my a/f at idle is higher than what it used to be @ around 14.7-9 from 14.0-14.3.
-does the timing need to be pulled/advanced when the ignition harness is hooked up or is it supposed to be zeroed out?
-what could be causing the misfire code?
i've run out of daylight today so i will try to get some more work done tomorrow or i will have to go back to stock.
any help?
Old Sep 10, 2005
  #64
andyman97's Avatar
Turbo Guru
Misfire is caused by:
Lack of fuel
Lack of spark
Check your #2 coil pack for voltage and check your #2 injector for voltage. Start there and see what you come up with. I would tell you what the voltage references were but I don't have my helms with me. Odds are that it isn't starting because you have no combustion in that cylinder.
Old Sep 10, 2005
  #65
Blahman240's Avatar
Touch it... He won't bite, He'll just come at you pretty quick.
Blahman240 is on a distinguished road
I didn't read the other posts but, I always thought In ment to the ecu, and out ment to the device.
Old Sep 10, 2005
  #66
andyman97's Avatar
Turbo Guru
It's all explained in my writeup how to wire it. If it's unclear, let me know and I'll revise it.
Youshoe
May 22, 2015 09:36 PM
chgofirefighter
Apr 18, 2015 08:08 PM
CivicVoz
Apr 16, 2015 08:07 PM
PimpBot5000
Nov 26, 2001 07:15 PM
Flatlander
Nov 16, 2001 05:38 PM
