who runs 75
Old Jul 11, 2005
allmotor's Avatar
nor cal 7thgens
who runs 75
Just wondering who runs a 75 shot on stock internals, and stock clutch. I only jetted 50 once but plan to run 75 a couple of times at the track in august. I just changed my plugs and i am gonna run 91 octane gas with 1 can of octane booster and then when i hit the track i will mix the rest of the gas with probably 103 or 106 octane vp gas. If anyone changed there clutch how long did it last spraying with the 75. My clutch still feels good even after spraying so i just was wondering.
Old Jul 11, 2005
scansel912's Avatar
scansel912 is just really nicescansel912 is just really nicescansel912 is just really nicescansel912 is just really nice
I'll do it if you do it.... Hahaha
Thiscrackerntam used a 75 shot as soon as he bought the kit. Used it that way for over a year. I know he changed his plugs everytime he got his bottle refilled and used premium gas. Had his stock clutch as well. He eventually blew his headgasket because his bottle pressure was over 1000 while spraying and sprayed in 5th gear. So my advice is just check your system before you try it. Is 91 the highest you got at the pump? Here in Ohio theres 94 octane at our local gas station.
Old Jul 11, 2005
allmotor's Avatar
nor cal 7thgens
yeah 91 is highest but people tell me they have a gas station in stockton on charter way that has 100 octane. I will probably just fill up with that and maybe octane booster. Yeah at the track i wont even get to 5th so thats cool. I just changed my plugs and added a half a bottle of lucas upper cylinder lubricant/fuel injector cleaner so i think i will be alright.
Old Jul 13, 2005
2K1Civic17"Gabe's Avatar
we only have 91 as the highest octane (premium) in Phoenix. Probably cuz its so much hotter though. I think the colder states have a higher octane since its more needed. We have 104 down the street from my house. Just so damn expensive.
Old Jul 13, 2005
djmota's Avatar
i have not tried the 75 jets yet. I have been using 65 My clutch just started to slip a bit in third at the track. this was after 2 bottles and 64,000 miles. Its not bad but since I am running for time its useless to run a slipping clutch at the track. head to the track with just a few gallons of 91 in the tank and pick up a couple gallons of the vp unleaded racing gas. skip the octane booster they don't work as well as mixing in the real stuff.
Old Jul 13, 2005
SpdRcrChk's Avatar
BOOST JUNKY
SpdRcrChk is an unknown quantity at this point
I used to have a 75 shot on my civic. Of course...we get 93 octane down here. I ran the 75 shot for a good amount of time....made 180whp and 208 wtq on that also. I also changed my plugs every other bottle. NGK coppers are good for that, nice n' cheap. I ran an NX wet kit, never had any issues. I totally recommend at least an safc or vafc so you can smooth out the air fuel. But yes, it can be done, and it's quite nice!
Old Jul 13, 2005
allmotor's Avatar
nor cal 7thgens
alright thanks for all the help everyone. Yeah i am gonna order the safc this thursday.
Old Jul 13, 2005
aziatik1.8t's Avatar
aziatik1.8t is an unknown quantity at this point
don't waste money on octane booster...it won't do much to raise octane levels
Old Jul 13, 2005
allmotor's Avatar
nor cal 7thgens
alright thanks s.
Old Jul 14, 2005
Redline04's Avatar
AKA Mr. 60ft. Not to be confused with Civic_Redline
Redline04 is an unknown quantity at this point
Gonna stick with a 35 for now and see what times I can pull, 50 shot soon after and 75 shot after SAFC and new clutch. Speaking of SAFC is it possible to run a NA tune and then switch to a a N20 tune? I thought I heard somewher that it was but you just have to kill the ignition in order to switch over. Anybody?
Old Jul 14, 2005
allmotor's Avatar
nor cal 7thgens
yeah i am sure u can do that. I just purchased it today so will see what happens
Old Jul 15, 2005
KnocturnalEM2's Avatar
I am your Mom's Hero!!
Nope you cannot switch per say while the car is running...car has to be in the on position without the car running while adjustments are being made!!!
Old Jul 15, 2005
djmota's Avatar
You wont need a n20 tune since you are running a wet kit. Just tune your car for na and spray on that. The wet kit is designed to keep you in a safe af ratio. All you have to do is keep bottle pressure where it should be and enjoy.
Old Jul 15, 2005
allmotor's Avatar
nor cal 7thgens
oh gotcha. Thanks for the info
lilrob1213
37
Jun 29, 2015 06:45 PM
hokiedad4
May 3, 2015 10:06 PM
dragonsblood
Apr 27, 2015 12:28 PM
Dmitri
123
Oct 13, 2005 08:01 PM
JoeB16
61
Oct 16, 2003 07:58 PM
