obx turbo mani
Old Jun 28, 2005
kingofvtec's Avatar
New Member
kingofvtec is an unknown quantity at this point
obx turbo mani
the new obx mani with the obx plate on it is a hella lot stronger than the old ones that ive seen pics of i havent seen any complaints on those i have one myself and their tubing is thicker and stronger than the old ones if anyone has seen any cracked ones let me know
Old Jun 28, 2005
R1Style's Avatar
ok....
Old Jun 28, 2005
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
i seen a obx mani at this place called TRIZONE. The WG flange had fell off.
Old Jun 28, 2005
18inchpride's Avatar
18inchpride is an unknown quantity at this point
OBX and turbo Manifold, are two things you never want to get confused with!
ONE WORD>>>>> JUNK
Old Jun 28, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
good stuff
Old Jun 29, 2005
civic01vtec's Avatar
Old Jul 25, 2005
BlackFire's Avatar
BlackFire is an unknown quantity at this point
It will work. It have two brackets from the turbo flange to the head flange wich makes it more resistant to the weight. It have another bracket from the turbo flange to the wastegate flange. Now, it still uses the same material and is as thin as the older ones. What you should do is have another bracket from the turbocharger to the engine block so it have even less stress on the manifold. By doing this it will last longer.
Old Jul 25, 2005
C2i0v0i1C's Avatar
SuperMODrizd
live and learn the hard way
Old Jul 25, 2005
turboengnr's Avatar
DONT PANIC
then you should take the runners off and reinforce them with newer, thicker ones, then weld them on with a stronger bead, and im sure it will last even longer!
Old Jul 25, 2005
C2i0v0i1C's Avatar
SuperMODrizd
after saying hack it up and use the same thin *** runners say good night to this thread
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
SammySC
121
Apr 7, 2017 07:43 PM
solarpunk70
Apr 12, 2016 11:43 AM
HondaGuy7
Feb 22, 2016 01:00 PM
sccarally
Texas
Sep 27, 2015 03:33 PM
