why smoking weed on the can is wrong
Old Jun 23, 2005
Veloz_Racer's Avatar
Veloz_Racer is an unknown quantity at this point
http://www.superstreetonline.com/plu...9_d17turbokit/
did i miss something? are they saying we can get 325 hp on our d17? please let me know if this is very wishful thinking.
Old Jun 23, 2005
C2i0v0i1C's Avatar
SuperMODrizd
that wouldnt give you 325-350 horses on anything
Old Jun 23, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
no way. a t28 can't output all those power anyway.
Old Jun 23, 2005
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
So, you go from a kit that gives you 170 hp, then just change to a larger turbo and go to 325 hp?
Old Jun 23, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
^^^ no way. you better rebuild the whole motor b4 trying to up the boost.
stock internal are good for 10psi. 325hp you need (rough est.) stock 325hp-127hp=~200hp. That is 20+psi. no way in hell a d17 can handle those kinda power.
Old Jun 24, 2005
civic01vtec's Avatar
good marketing
Old Jun 24, 2005
eye_see_you's Avatar
let the devil out
the TSI kit which is what I'm running can put down .. but the stock internals cna only handle a max of 15 PSI and thats pushing it I run 12 on my setup daily and yet to have a engine problem at all
Old Jun 24, 2005
LayinLo's Avatar
LayinLo is an unknown quantity at this point
Originally Posted by SuperStreetOnline
167 hp and 160 ft/lbs at the wheels!
Turbo Specialties answers the D17 Cognoscenti
Turbo Specialties, Inc and Turbo-Kits.com have answered the demand of all the red-headed stepchildren (otherwise known as a 2001-and-up Civic owners) by developing a new bolt-on turbo kit for the underpowered 1.7L SOHC. The fast-spooling T25 turbo allows the 1.7L to belt out 167 hp and 160 ft/lbs at the wheels or 200 hp and 192 ft/lbs measured at the crankshaft. These figures are made at only .4 bar (6 psi). Full boost is reached at 2500 RPM. This turbo kit will not win any dyno wars or make you a hero on Honda-Tech.com, but it will produce enough power and torque to make your drive more enjoyable, while still giving you the ability to drive it everyday. Like many factory turbocharged vehicles, you can upgrade the system by swapping out the T25 with the higher-flowing T28 Ball Bearing turbo which will give you 325-350 hp at the wheels (with proper tuning).
Definitely good marketing. You gotta read between the lines on this one.
Old Jun 24, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
I said someone email them and ask. how the fuc* u can get another 190whp by swapping a turbo.
Old Jun 24, 2005
supermex's Avatar
supermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to all
even with internals at 250 hp and above you'll blow the axels and trany
Old Jun 24, 2005
gotti's Avatar
roflcopter engaged. what a bunch of fagtards
Old Jun 24, 2005
TheSmuggler's Avatar
lemme get my wtfbombs out, no wonder we see so many noobs going out and buying this kit LOL
Wiggles
Sep 8, 2015 05:05 PM
thaler4cuse
Sep 7, 2015 08:25 PM
NaturalSelectio
Sep 6, 2015 06:59 PM
JohnDay
Wheels and Tires
Sep 6, 2015 06:42 PM
tooly145
Sep 5, 2015 01:05 AM
