Differences in the Hondata ECU's.
Old Jun 25, 2005
PrecisnTec's Avatar
PC Tech / Autocrosser
PrecisnTec will become famous soon enoughPrecisnTec will become famous soon enough
I'm sure each ECU option is application specific but I really couldn't get a clear (dummy's) explanation for the differences in the K-Pro, K100, and Reflash.
Reason why I am asking, I'm just probing the possibility of of a k-swap but trying to research every component before I set it in stone that I will do it. I did do a search and didn't turn up any results. Anyone care to take a few minutes to help the newb? Where I'm getting stuck on my research is 1) The immobilizer and keeping it workable (which I know I could use a stock ecu and just have the dealer reflash it with the key) and 2) Instrumentation. Can you still use your existing lx/ex gauges for speed/tach, idiot lights or will you have to use the instrumentation from the donor vehicle?
Thanks again.
Old Jun 25, 2005
TheSmuggler's Avatar
The k-pro is bascially an adjustable output, and the reflash is a one time, flash and your done deal. The most common reflash is a #4, put if you bought k-pro you can load up the #4 profile and tune it a little more. The k-pro #4 profile is also a tad bit more agressive than the standard reflash. You can still use your stock gauges, but you'll have an easier time if you just swap over the series gauges that the motor came with. The immobilizer, well you got me on that opne, I'm pretty sure that you don't need it reflash on the #4 reflash ebcause your ecu is still partially intact, not sure on the k-pro though.
Old Jun 25, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
You use the k20 motor ecu and take it to acura to get it reflash. not our stock one.
stock one work and if you decided to use the acura. it require some mod. and fab.
Old Jun 25, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
obw. I think the K-pro, k100, and other ecu from Hondata. They kill the immobilizer. (someone correct me if I am wrong)
Old Jun 25, 2005
See thats what I didn't know, I thought that they actually reflashed parts of it, but left the immo intact...
JetsterDajet
Aug 16, 2015 01:56 PM
Klame9420
Aug 13, 2015 06:00 PM
Pwelsh
Engine start problems
Jul 9, 2015 04:15 PM
