Need Help Piecing My Turbo
Old Jun 21, 2005
Chris3k2's Avatar
Chris3k2 is an unknown quantity at this point
Ok these are the things I already have for my custom turbo kit.
- HKS Exhaust Manifold
- Garrett T25 Turbo
- Intercooler
- Greddy Type RS Blow Off Valve
- RSX-S Fuel Injectors
These are the things I know I need to get:
- Greddy Emanage
- Intercooler Piping
- Fittings and **** like that
- Gauges
First I need to know whether this piping would be ok to use for the turbo, Intercooler Piping
Alright and if that intercooler piping is ok to use what should I get first???
1) The Emanage
2) The piping
3) or the Gauges
And finally what else would I need besides everything that I listed??? I would greatly appreciate some help.
Old Jun 21, 2005
meseetree's Avatar
meseetree is on a distinguished road
well first off that will not be all the piping you need you will need one to go to the throttle body and one to go to the turbo.
as far as what to get you need piping you should have gauges but the greddy emanage is not needed untill pushing high psi like 11 or more
Old Jun 22, 2005
tfnaaf's Avatar
BLDNPSI Mod
What you NEED, is dendant on your view
Some sort of fuel management will be needed and the e-manage would be a good proven choice.
BoV flange
Pipe for Down pipe
Flange for Downpipe
O2 sensor bungs
Flange from DP to exhaust pipe
Gaskets for manifold to head/manifold to turbo
oil supply line (and fittings)
oil drain line (and fittings)
Brass "T" and fittings for supply/ or oil filter sandwich adapter
is it a water cooled T25? if so hoses and fittings for that
Return conversion would be nice but not a MUST have
Wide band would be nice but not needed
Vacuum manifold of some sort
oil pan gasket
and im SURE there is LOTS im forgetting
Old Jun 22, 2005
tfnaaf's Avatar
BLDNPSI Mod
its the little stuff that adds up ive found!
Old Jun 22, 2005
tfnaaf's Avatar
BLDNPSI Mod
Colder Spark plugs
Oil
Filter
Old Jun 22, 2005
Chris3k2's Avatar
Ok I got the spark plugs tooken care of and the gaskets. Where could I get some of the other parts from. I'm going to have a downpipe custom made. Oh and I have an LX too. The turbo also is internally wastegated as most of you already know.
Old Jun 22, 2005
tfnaaf's Avatar
BLDNPSI Mod
I got a lot of my turbo stuff from HERE But there are many suppilers even here on the boards like Dezod . My GT28R required that i fabricate a mount for the wastegate after i clocked the turbo to where i needed it. Check out my pictures if you would like to see....
Old Jun 22, 2005
dezod's Avatar
7thgen Power Maker
We carry an array of flanges and such you may need to go custom.
Old Jun 22, 2005
Chris3k2's Avatar
dezod could u make a custom downpipe for my setup and if so how much would that be?? Or maybe I can just come down to florida for a while and get some of the things when I go and you could show me what else I would need???
Old Jun 22, 2005
Chris3k2's Avatar
you got any more pictures tfnaaf?? That looks really nice.
Old Jun 22, 2005
tfnaaf's Avatar
BLDNPSI Mod
look herehttp://www.7thgencivic.com/memberrid...0/ppuser/18773
Old Jun 22, 2005
Chris3k2's Avatar
do you have an ex or lx tfnaaf???
Old Jun 22, 2005
tfnaaf's Avatar
BLDNPSI Mod
LX with an auto trans
Old Jun 22, 2005
Chris3k2's Avatar
I have an LX 5 speed. What all did u have to move/relocate in your engine to fit your piping?? and did you install it yourself and if so was it pretty easy??
Old Jun 22, 2005
tfnaaf's Avatar
BLDNPSI Mod
I had to fabricate all the piping myself (welder and power cutoff band saw) I relocated my winshield washer bottle with an aftermarket bottle that is shown in my pictures. The install is still on-going but im taking my sweet @$$ time. Only thing left now is the rsx injectors and tunning and im done. I've done all myself and i wouldnt say it was easy, but then i wouldnt say it was hard either.
Jaryn
May 17, 2016 02:52 AM
ricer_em2
May 11, 2016 08:09 PM
HondaGuy7
Feb 22, 2016 01:00 PM
pilebuck13
Sep 21, 2015 10:45 PM
Jrosa
Sep 14, 2015 08:24 PM
