Someone fast! What kind of oil to use on a turboed Civic?
Old Jun 21, 2005
Hwoody77's Avatar
Hwoody77 can only hope to improve
Anyone know what kind of oil I should be using? Let me know fast!
Old Jun 21, 2005
atl01's Avatar
this has been an atl01 production..
atl01 will become famous soon enough
Just keep using the same oil that you have been using since you had your car. You shouldnt have to switch your oil just becacuse you went turbo. The only way i would switch oil is if your turbo had a bad seal or something then i would use a heaiver weight oil to keep it from burning past the seals. Maybe you could switch to a synthetic.
Old Jun 21, 2005
riceburnrex's Avatar
First to spool
riceburnrex has disabled reputation
Synthetic will hold the heat better. I'm using Mobil 1 5w-30 and it works great. It's got the heat range to handle a summer day at the road course track while still being light enough to lubricate everything on the motor.
Old Jun 21, 2005
C2i0v0i1C's Avatar
SuperMODrizd
i use synthetic too
Old Jun 21, 2005
Drk01Civic's Avatar
Drk01Civic is an unknown quantity at this point
Yeah, synthetic 5w-30 over here.
Old Jun 21, 2005
Alex1's Avatar
i thought we were supposed to use a heavier weight like 10W30 or 10W40?
Old Jun 21, 2005
dezod's Avatar
7thgen Power Maker
Originally Posted by atl01
Just keep using the same oil that you have been using since you had your car. You shouldnt have to switch your oil just becacuse you went turbo.....
You should switch to synthetic oil because it has a higher viscosity than dyno oil. Mobil 1 or Amsoil. 5w-30 or even 0w-20 (I have seen some people switch to).
Old Jun 21, 2005
Michalo187's Avatar
Abortion Survivor
I use mobil 1 5w-20 works excellent so far if you read the back it says tested to handle turbocharged and supercharged vehicles
Old Jun 21, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
Mobil 1 Synthetic 10W-30
Old Jun 21, 2005
Michalo187's Avatar
Abortion Survivor
Has anyone tried Royal Purple??? They make 5w-30 and 10w-30
Old Jun 21, 2005
gotti's Avatar
Mobil 1 10w-30 Synthetic
Old Jun 21, 2005
2K1Civic17"Gabe's Avatar
same here. Works awesome. Mobil 1 10w-30 synthetic and Mobil 1 synthetic oil filter
Old Jun 21, 2005
Michalo187's Avatar
Abortion Survivor
So should we use 10w-30 or 5w-20 ??? My mechanic told me to use 5w-20 cause it might mess up the cam with thicker oil and that if there was no need to change it to thicker thats fine. I wanted to try Royal Purple
Old Jun 21, 2005
slammedSI's Avatar
slammedSI is an unknown quantity at this point
hey im a firm beliver in royal purple, i use it in every thing from motor oil to coolent. my dad has a 04 tahoo and he went to royal purple motor oil, tranny oil, rear dif oil and gained 4 miles a gallon just off that. dont let any one tell you other wise. thats some good ****!!!!!
Old Jun 21, 2005
Michalo187's Avatar
Abortion Survivor
does it actually add hp like its say
Old Jun 21, 2005
civic01vtec's Avatar
same here
LionSpratt
Jan 29, 2017 11:07 PM
ChristinaVHH
May 10, 2015 03:51 PM
tylerginevan
Apr 27, 2015 12:29 PM
Rinzlor
Apr 24, 2015 10:33 AM
vtechcivic
Apr 21, 2015 06:58 PM
