MSD Boost Adjustable Fuel Pressure Regulators
It will work, but you can only adjust the fuel pressure up to 45psi. If you are going to put turbo on, i will suggest you buy aeromotive one, which will allow you up the fuel pressure to 70 psi. It is better to have that feature in case the injectors max out, so you can just up the fuel pressure.
i already have a turbio on running 4 psi i have the typ S injectors whiut a VAFC2 untunet ill be on the dyno next month im not sure to get that fue pressure what u all think
return fuel system.... your returnless will kill you on high boost. Don't stary above 8 psi with your type-s injectors until you go return.
a return system sold as a kit will more than likely have a fuel pressure regulator. as stated above, you will want a fpr that i capable of more than 45 psi. the stock fuel pressure is around 43 psi so thats not much to work with. get the aeromotive if you want a good fpr.
Abb0nz
Jun 23, 2015 06:10 PM
mrcell24
May 19, 2015 10:02 AM
BREADFAN
Apr 15, 2015 08:58 AM
