Need help with coolant resovoir
Old Jun 12, 2005
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
ok for some reason since I been boosted, it looks like my coolant resevoir is splirting out coolant. I dont know when this happens but after hard driving or even mild driving I pull over and pop the hood and some coolant/water is on the resevoir, not too much but you can see some did splirt out. The actual coolant isnt leaking only the resevoir and I cant tell when it does it cause by the time I come out its not leaking or anything.
Can anyone help me fix this problem or is this normal?
I didnt blow a head gasket. I never saw the temps go above right below middle. Max I been boosted was 8-9 psi cause I spiked.
Someone give me some suggestions here. Btw I got check engine light today, but I dont thinks thats because of the coolant because the coolant has been doing this for past week or so..
I am pretty sure this is because of the turbo because I never had a problem like this before when I was N/A even if I floored it all the time. Could it be because Im in boost constantly and my engine bay gets really hot?
Old Jun 13, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
Forget the idiot gauge, do you have a real watertemp gauge in the system?
I'd be hard pressed to believe its boiling, but it could happen. Check the hose for a tiny hole... thats always a possibility.
Old Jun 13, 2005
Logan3024's Avatar
NOT NORMAL
Its your headgasket. I drove about 400 miles with my headgasket blown. It just depends how bad the condition of the headgasket is. I had no oil in coolant or anything, first sign was the coolant filling up the resovoir. When that happens the cooling system is releiving pressure, which is caused by heat (blown headgasket).
Mine went due to running to lean, that might be your problem also.
PS i wasted about 100$ buying new thermostat, fan switch, relay replacment ect just because the "normal" signs of a blown headgasket wernt there.
Old Jun 13, 2005
C2i0v0i1C's Avatar
SuperMODrizd
im having the same damn problem, mine is spewing out everywhere all over the place too
Old Jun 13, 2005
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
i just replaced my hg for the second time, it sux, coolant was being pushed in the res tank.. . i tqed the stud bolts diwn to 55 foot lbs this time
Old Jun 13, 2005
im stock now! T.T
what else should I do? so the temp never went up, wonder if I blew a head gasket. there is no hole in the host or anything. I think Im running lean cause the sf fmu isnt all that great...
Old Jun 13, 2005
Michalo187's Avatar
Abortion Survivor
I had that when i was N/A it was my head gasket also. Now my problem is ever since i have been turbo my coolent level keeps dropping everyday i put coolant in and it always gets lower and lower i notice because my car temp rises in long drives or at idle then when i fill it up it stops. My turbo is water cooled could that be it?
Old Jun 13, 2005
Michalo187's Avatar
Abortion Survivor
Civic_Redline what injectors are you running? Any piggyback system?
Old Jun 13, 2005
im stock now! T.T
just the missing link and sf fuel management unit which is just a fuel pump, Im gonna switch to srt injectors and e-manage or ems, right now I think Im running lean cause of the sf fmu. Hopefully that will fix the problem? or is my headgasket already blown and need to be replaced?
Old Jun 13, 2005
SODJAZERO's Avatar
well, you can do a return fuel line and get a regular 12:1 fmu, or you can do a return fuel line and get emanage ect, return fuel line set up is easy to make also.. .
Old Jun 13, 2005
Michalo187's Avatar
Abortion Survivor
If your head gasket is blown you gotta get it replaced and you cant hold that off. Rsx injectors is what you need and a emanage to get it tuned
Old Jun 13, 2005
SODJAZERO's Avatar
yah you dont wanna get a warped head
Old Jun 13, 2005
im stock now! T.T
so when do I know when my hg is blown?
Old Jun 13, 2005
CIVIC808's Avatar
CIVIC808 is an unknown quantity at this point
it is blown,replace it.i know cause it happened to me.
Old Jun 13, 2005
im stock now! T.T
are u serious? I dont leak coolant all the time only when I drive for long period of time and under boost constantly, I figure I drive it softly for a while, my temp dont even go up when I go wot constantly. U 100% I need to replace it now?
im only boosting 4 lbs normally, max 6psi. how could my hg blow so quick and easily?
Old Jun 13, 2005
Havok2k1's Avatar
Wicked Pissah Admin
Only time it would happen is when the Head gasket is done. Just get it replaced and get a better fuel system.
as far as the question of why it happened so quick, all it takes is one misfire and you're done....
Old Jun 13, 2005
MadWheel's Avatar
Premium Boosted Member
I agree with everone else. It's definately blow. My engine did the same thing.
Buy the nippon leakless headgasket for about 22-26 bucks. Switch it out, then you can boost happily. Stock headgaskets are weak as hell, and go very quickly. Replace it soon, I drove "softly" as you said for a lil while but soon enough it started happening with that right away as well. Good luck with everything though, it isn't as bad as you think.
Old Jun 13, 2005
Michalo187's Avatar
Abortion Survivor
It happened so fast because your racing Mustang Gt,Sti and other 300hp cars and pushing your car to the limit with a cheap fuel system untuned and when your racing you probably get boost spikes remember why you asked why you shouldnt boost in 5th thats why
Old Jun 13, 2005
im stock now! T.T
lol, ok. Well now I guess I have to use my electronics money to get hg replaced and getting the nippon one since no aftermarket one for our cars, damn this sucks.
Old Jun 13, 2005
Michalo187's Avatar
Abortion Survivor
Thats an expensive job btw and its a bitch i know by experience
Old Jun 13, 2005
2K1Civic17"Gabe's Avatar
where can I find this hg. I have been spilling coolant occasionally. I can go weeks without filling it up. But at times, after boosting for a little while, it will spill some out the top. I was told this is normal, and because the coolant expands when it gets hot. I have a little smoke out of my exhaust. Usually just when warming up thoug or shifting. I usually only spray it out when there is more than the max in the resorvoir. I need to put some distilled water in there as well. I only have coolant in it right now.
So how long does it take to change out the hg? an hour? Doesnt seem like it would take too long, but than again, everything takes way longer than estimated.
Old Jun 13, 2005
im stock now! T.T
I lowered boost to 4 so it wont spike, I should have kept it there. I drove hard in some spots, the coolant was still spraying and not much only when I keep on the gas. Im going to leave it at 4psi and change the hg to nippon one. Will the arp headstuds be a good purchase?
Old Jun 13, 2005
Michalo187's Avatar
Abortion Survivor
where gan you buy the nippon head gasket???
Old Jun 13, 2005
im stock now! T.T
just went to the dealership and they told me thats all they had, the one they had before which is another brand was discontinued.
Old Jun 13, 2005
Logan3024's Avatar
Well just remember redline the longer you wait to replace the more money your gonna end up spending, alot more oil is going to building up in your water jackets, causing the coolant to flow less and less. took me about an extra hour cleaning and flushing the jackets. It will get worse eventually trust me. Your also running the chance of warping your head due to continuous overheating, which will require milling which is $$$$
I bet you dont have any white smoke coming from your tailpipe right? i didnt either.
Old Jun 13, 2005
im stock now! T.T
no smoke. Just some coolant when opening hood later there are stains. I could never get it tospray coolant out even if Im pulling the throttle cable in the engine bay to rev the engine to get it hot.
I am going to switch it soon. hopefully by 2 weeks. My cel light came off also after lowering boost. I dont know if the cel was from my megan resonator pipe becuase it doesnt cause a cel for me ever since I installed the spark plug non-fouler. The cel stayed on for a day.
Old Jun 13, 2005
turboengnr's Avatar
DONT PANIC
some of the sf fuel systems had a 10:1 disc instead of a 12:1 like the civics need. If thats the case, there is the reason it *could have* gone lean.
Or you could have weakened it by using an 80 shot of nitrous and the turbo finished it off.
Old Jun 13, 2005
im stock now! T.T
i hope mine has 12:1 disc, you dont remember if the last one u made had 12:1 or 10:1?
Old Jun 13, 2005
tfnaaf's Avatar
BLDNPSI Mod
If you want to confirm that the head gasket is blown. Most general repair shops have a combustion checker. It sticks into your radiator and has a chemical in it that senses the combustion gases in the cooling system and changes colors of the chemical. Its a real fast test and fairly inexpsensive.
Old Jun 14, 2005
im stock now! T.T
is it called a leakdown test?
