anyone with turbo running everything else completly stock?
Old Jun 3, 2005
Blahman240's Avatar
Touch it... He won't bite, He'll just come at you pretty quick.
Blahman240 is on a distinguished road
Like everything else is stock, with some intent in the future to upgrade. I mean, stock injectors, plugs, downpipe, all that good stuff... Anyone?
Old Jun 3, 2005
2K1Civic17"Gabe's Avatar
id make sure you have injectors of some sort to get enough fuel there. downpipe, you can use your stock one if you want. plugs you could run, but it wouldnt be safe. you would want those before you boost since they run cooler. (ik20 or 22, I forget what one).
Id make sure you have everything you need before you boost, so you have more uptime, and less downtime from not doing it right
peace
Old Jun 3, 2005
Blahman240's Avatar
well... could I run a turbo without even like an emanagement or vafc?
Old Jun 3, 2005
Hwoody77's Avatar
Hwoody77 can only hope to improve
You could but you wouldblow your motor in a seconds, upgrade at least injectors, and a VAFC...
Old Jun 3, 2005
Blahman240's Avatar
well... I'm thinking e-manage right now, cause dezod provides working maps, although I know every car is different, but I can atleast use it till I get tuned.
Old Jun 3, 2005
kingofvtec's Avatar
New Member
kingofvtec is an unknown quantity at this point
what will i need
i have an 05 civic and i just ordered turbo, manifold and piping but since ive been reading these threads i see that i need more stuff im new to boost so can someone please tell me everything i need in order to run at 8 psi of boost without blowing my engine and where i can get it thanks
Old Jun 4, 2005
eye_see_you's Avatar
let the devil out
i'm running a 02 ex sedan with stock internals on a TSI extreme kit @ 12 psi
Old Jun 4, 2005
Michalo187's Avatar
Abortion Survivor
I have to upgrade my plugs because i have blown three sets already because the turbo produces so much heat it screws them. You gotta run colder plugs Some Injectors and e-manage to me is the best but everyone has different views. I wanna get better internals so i can run like 18 psi like the srt 4s then we will see who is cocky.
Old Jun 4, 2005
-larger injectors
-2 plugs colder than stock for your new spark plugs (auto store can tell you what ones are 2 colder)
-something to tune the injectors with (eManage, vafcII, safcII)ABSOLUTELY NEEDED
-tune it
-intercooler is good to have definately, otherwise the air is pretty damn hot going into the motor
-wastegate
-wideband a/f gauge, boost gauge, egt gauge is good to have
-pay for a tune
-boost controller if you want to turn the boost up more than the wastegate setting, when you buy a wastegate, I would get one with a 6psi spring, unless you plan on boosting like crazy (blown motor)
-there is more, but that will get you boosting pretty reliably.
PM StreetLevelPerformance, or Dezod. They can help you with any parts you may need to buy.
Old Jun 4, 2005
Blahman240's Avatar
Originally Posted by 2K1Civic17"Gabe
-larger injectors
-tune it
-wastegate
-pay for a tune
forgot blow off valve, oil lines, and there is quite a bit more. Like um... what do you call them things you put on flanges so they don't leak... can't think right now. Gaskets?
ghondavic
Transmission
Apr 12, 2017 09:37 PM
Ninetyatecivic
May 9, 2015 07:48 PM
Supramk3
May 8, 2015 11:16 AM
ej8
Apr 13, 2015 06:36 PM
artychris
Nov 10, 2001 01:06 PM
