SLP Return Kit help! *update 8/26/05*
Old May 29, 2005
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
UPDATE: SEE LAST POST.
I installed my slp return kit yesterday.. got everything hooked up but when i go to start it, it won't start. Doesnt seem to be getting fuel pressure. When you Put the ignition on. is the fuel supposed to start flowing? The fuel pressure gauge is reading 0. I hear the pump turn on when i turn the ignition on but it wont start. Does the fuel pressure regulator in the tank need to be bypassed? i'm really stumped on what the problem is. I tried to contact Jeff from streetlevelperformance but i havent gotten a response yet. Any body got any suggestions?
Old May 29, 2005
XSRCivic's Avatar
bump? please help!
Old May 29, 2005
tfnaaf's Avatar
BLDNPSI Mod
looking for pictures....
Old May 29, 2005
XSRCivic's Avatar
^^ thanks man, i searched this site up and down, couldnt find not a 1
Old May 29, 2005
tfnaaf's Avatar
BLDNPSI Mod
Dose it look similar to my photo? I assume that you did remove the in tank regualtor , i think you just about have to? Im not sure what all came in your kit? did it come with new walbro pump?
Old May 29, 2005
XSRCivic's Avatar
damn man you are awesome.. yeah it looks exactly like that except the intank regulator wasnt removed.. i didnt see that in the directions.. i read them 50 times..
Old May 29, 2005
XSRCivic's Avatar
it came witha walboro pump and aremotive fpr so i DO have to remove the stock fpr?
Old May 29, 2005
tfnaaf's Avatar
BLDNPSI Mod
hmmmm, on the output of that pump is that little fitting looking thing? that is the regulator. It should be removed then the hose clamps on the end of the pump then up to the filter housing as in my picture. Not sure if thats why its not building pressure thou. Did you have to install the new hose in the tank, and cap off the other fititng on the filter as shown in my picture?
Old May 29, 2005
tfnaaf's Avatar
BLDNPSI Mod
As i recall the stock regualtor dont fit right on the end of the new pump. Its been a few months so im going off memory....i should have taken more pictures
Old May 29, 2005
tfnaaf's Avatar
BLDNPSI Mod
If you want i could take a picture of the part i removed, i think i may still have it?
Old May 29, 2005
XSRCivic's Avatar
no mines not capped off its still connected to the intank fpr.. i think thats the problem.. you have an external adjustable fpr in your setup right?
Old May 29, 2005
tfnaaf's Avatar
BLDNPSI Mod
yup, the areomotive, prolly just like yours, look in the picture above you can see the stainless steel hose i used to cap off the stock return
Old May 29, 2005
XSRCivic's Avatar
alright so there is no fuel going into that hose correct?
Old May 29, 2005
tfnaaf's Avatar
BLDNPSI Mod
what happens is the pump build pressure it goes out the black hose in picture, into the filter(main hosing at top) the second fitting (stainless steel hose) must be capped off or all pressure will just dump back into the tank.There will be pressure in that stainless steel hose so it must be a good conection that wont leak.
Old May 29, 2005
tfnaaf's Avatar
BLDNPSI Mod
here is the stuff that needs to be removed ....
Old May 29, 2005
XSRCivic's Avatar
ok i understand.. that helps me out so much man thanks lotsa rep for you ! you're a civic saver
Old May 29, 2005
XSRCivic's Avatar
damn wtf? still no pressure.. i dont understand it, i removed the stock fpr all my connections are right and it still doesnt get pressure, i even tried the stock fuel pump and still nothing.
Old May 29, 2005
Hwoody77's Avatar
Hwoody77 can only hope to improve
Same problem....I cant figure it out, anyone know what's going on?
Old May 29, 2005
ex_03's Avatar
Godlike member
ex_03 is on a distinguished road
Did you test the pump before putting it in the tank? Becuase I have heard that if this done without submerging it, it will burn the motor out. I am total noob when it comes to performance upgrades or motor work but, I have asked around about this very subject becuase I wanted to what you guys did.
Ps. I would take it out get a bucket fill it with gas and see for your self that its pumping the right way and not leaking back into the tank, I know its alot work but you'll know for sure thats its not the pump.
Old May 29, 2005
fastest_ex's Avatar
fastest_ex is an unknown quantity at this point
whats the website for the return feul line kit...it wolud help us figure it out
Old May 29, 2005
tfnaaf's Avatar
BLDNPSI Mod
well, you said the pump turns on when you first turn the key on, thats a plus! Only thing i can suggest is take the assembly out and look it over to see if you can figure out whats up. Any way you can take apicture of how its set up ?
Old May 29, 2005
XSRCivic's Avatar
streetlevelperformance.com but it doesnt really give install instructions. it just lists what is included in the kit.
Old May 29, 2005
tfnaaf's Avatar
BLDNPSI Mod
dont laugh at my fast drawing Does it look like this?
Old May 29, 2005
tfnaaf's Avatar
BLDNPSI Mod
assuming it looks like the above, then next question is at the regulator. The hose coming off of the fuel rail goes to one of the side inputs of the regulator, then the return to the tank comes off the bottom of the regulator, plug the other side port and i assume there is a gauge in the small pipe fitting on the front of the regulator. Next step is tunr the key on and adjust the pressure. This may take some cycling of the key on and off a few times to get the pressure set with the car not running. Once you have SOME pressure at the regulator then start the car and adjust it to desired pressure.
Old May 29, 2005
XSRCivic's Avatar
ok everything is exact as pictured above.. still no pressure.. how long does it take "cylcing of the key" to notice any pressure at all?
Old May 29, 2005
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
Did you try adjusting the FPR? The **** is at the top of it.
Old May 29, 2005
XSRCivic's Avatar
i did try adjusting the **** many times but still same effect. 0 pressure.. i even tried the stock pump with this setup and i get the same effect 0 pressure.. i had to put everything back to working order because i need my car drivable this week. it will not be until two weeks that i try this again so we have 2 weeks to come to a solution. hopefully we can get this figured out.
Old May 29, 2005
tfnaaf's Avatar
BLDNPSI Mod
Old May 29, 2005
XSRCivic's Avatar
well i got to talking with jeff @ streetlevel. I flow tested the fpr and the stainless steal lines for blockage and everything was alright.. the only thing left that it could be is that the pump is getting blocked some how from the way its sitting in the cage so i'll end up taking it out again to readjust the fitment. this wont be until 2 weeks however. i'll update this post with some pics and more info and probably do a DIY since no one has done one yet. wish me luck
Old May 29, 2005
tfnaaf's Avatar
BLDNPSI Mod
Opto_isolator did a pretty good DIY last year, but i dont think it ever got a sticky.
