My pretty sick turbo set-up...
Old May 26, 2005
Hwoody77's Avatar
Hwoody77 can only hope to improve
Finally, I am complete/ extremely close to completely my turbo kit. This is two years in the making, but I've finally got here...all the best of everything...
Maxrev Manifold
T3 Super 60 .48/.42 A/R
Customer Downpipe that goes straight into exhaust
HKS Carbon-Ti Exhaust
Tial 38MM Wastegate
Greddy Type S BOV
Intercooler
All custom piping (Stainless Steel)
Golden Eagle Vacuum Manifold
Greddy Profec E-01
Greddy E-Manage w/ Pressure sensor, Ignition harness, Injector Harness
AEM UEGO Wideband
Exedy Organic Clutch
Aeromotive Fuel Pressure Regulator
RSX Injectors
Walboro 255 LPH Fuel Pump
Modded fueal rail for return conversion
All stainless stell lines (Fuel and Oil)
And that's about it....I'm trying to do over 200WHP...so...
Old May 26, 2005
02LX's Avatar
02LX is on a distinguished road
very nice
Old May 26, 2005
tfnaaf's Avatar
BLDNPSI Mod
Good luck, I hope to be boostin soom myself on my custom kit
Old May 27, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
ummm.
Greddy Profec E-01
I though they are the same. Well not excatly the same, Greddy Profec E-01 has little bit more feature then E-Manage. Why do you have both?
Old May 27, 2005
Hwoody77's Avatar
The Profec E is a boost controller, the e-Manage isn't, the Profec E allows you to control/datalog the e-Manage with out a labtop...
Old May 27, 2005
Michalo187's Avatar
Abortion Survivor
how much psi? Goodluck dude make sure you shows us pics of the finished product
Old May 27, 2005
quick silver's Avatar
472rwhp @ 7400 RPMs and 12.93 psi
quick silver has disabled reputation
Maxrev Manifold
Tial 38MM Wastegate
Greddy Type S BOV
Intercooler
Greddy Profec E-01
AEM UEGO Wideband
RSX Injectors
Very nice setup. Only problem I see is that you are trying for over 200 whp. That is the problem with the D17 engines--even turbo-charged they aren't makin huge numbers. At least with a K20A2 you can say that when you turbo-charge it you will be tryin for over 350 whp. And that is a fairly conservative goal.
Old May 27, 2005
mkingk2's Avatar
mkingk2 is an unknown quantity at this point
You may want to change that Headgasket out...
How much it all cost ya?
Old May 27, 2005
civic2k2's Avatar
civic2k2 is an unknown quantity at this point
Awsome looking list especially that Carbon Ti very sexy. Your car is already badass cant wait to see all those goodies on it.
Old May 27, 2005
Michalo187's Avatar
Abortion Survivor
Its easy to get over 200 whp on a civic just ****ing run a large amount of psi the engine wont stand it unless you work on the internals but hell you can make a d17 produce some good hp with some work
Old May 27, 2005
turboengnr's Avatar
DONT PANIC
you dont need to change the head gasket. just tune the car well. You will only blow it if its poorly tuned and it detonates.
Sounds like a nice setup. Similar to mine. I have a bit larger injectors, 40mm tial wastegate, a 60-1 turbo, ACT clutch, and a stainless equal length manifold.
I am sure you will be more than happy with those parts. I had most of those parts on my car before, and i made well over 200 with the stock motor. Now im shooting a little higher, like the 500 whp range.
If you look at that and laugh, im sure my sponsors will slap you.
One of the best things you can do (and i recommend you do) is port the head. If you do that, you can make over 200 whp on 7-8 psi. I made 190 whp and 188 ft/lbs on 8 psi with 3 broken pistons and scored cylinder walls. I made 235 whp on 8 psi with a good tune, and a non-broken motor.
Old May 27, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
500whp? are you talking about with a k20a2??? I don't think a d series have the avaibility to reach that kinda of power. May a little secretly you may want to share.
Old May 27, 2005
turboengnr's Avatar
DONT PANIC
SOHC motors have the same potential as any other motor. All a motor does is get air in and out, right? The more air you get in, the more power you make.
I am completely re-designing the ports on the head. They dont even come close to resembling the ones that honda gave me to start with. We are flow-testing everything, and the numbers are looking awesome!
With enough boost, i should have no problem making that power. The bottom end is built stout as hell. Im planning on 425 whp on the turbo alone, then the nitrous on top of that.
I will share my other little secrets when the car is up and making that power.
Old May 27, 2005
turboengnr's Avatar
DONT PANIC
oh, and before anyone mentions it....
I am not making the ports as big as possible. I am keeping velocity in mind.
(i know someone would try to say something about that)
Old May 27, 2005
Hwoody77's Avatar
Well the initial point is 200 HP, then 300-350 WHP is my final goal...
Old May 27, 2005
2K1Civic17"Gabe's Avatar
yup, everybody wants to start with 200, than once that seems pretty slow (a couple days), you want more power. Everybody just says 200 so they dont get flamed I believe. I want to get up to 350whp, maybe more, and Ill be happy. (maybe)
Old May 27, 2005
civic01vtec's Avatar
i'd like to get 1000whp....but i'll stick with what i got.
Old May 27, 2005
chicohonda02's Avatar
Since 2002 Baby!
Old May 27, 2005
tfnaaf's Avatar
BLDNPSI Mod
Originally Posted by chicohonda02
Heres my pictures sofar
Old May 27, 2005
Since 2002 Baby!
Thanks
Old May 27, 2005
tfnaaf's Avatar
BLDNPSI Mod
turboengnr I have no doubt that 500whp is obtainable, not that ill ever get there on mine. But with time, and $$$ anything is possible. After all they said we never land on the moon, and the earth was flat
Old May 27, 2005
turboengnr's Avatar
DONT PANIC
Old May 28, 2005
JetBlu01's Avatar
New Member
JetBlu01 is an unknown quantity at this point
I think I'll stick with my 126whp....
ON MY 05 GIXXER 750
Old May 28, 2005
BIG's Avatar
BIG
awesome, I've got alot of the similar parts, minus the return setup....I hope to get some tips from you guys when it comes time for my install ( in a month or so). I wish you all the best with yours Hwoody!
-HondaFTW-
Aug 30, 2015 10:38 AM
bhollie
Aug 12, 2015 09:58 PM
justcruzin125
Aug 11, 2015 09:09 PM
ShaneShepley
Bolt-on Engine Performance
Jul 21, 2015 05:25 AM
