stock cat w/ nitrous ?
Old May 23, 2005
thefivespeeder's Avatar
thefivespeeder is a jewel in the roughthefivespeeder is a jewel in the roughthefivespeeder is a jewel in the rough
Some people say they've had cat failure because they run nitrous. Is this common? Is it worth it to go with the test pipe, because then you'll need an o2 sim or wb? Thanks-
Old May 26, 2005
2K1Civic17"Gabe's Avatar
Or get a high flow cat, and keep your car legal. Youll have a CEL w/out it.
Old May 26, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
if you get test pipe then u need an o2 sim to get rid of CEL. I don't think you need wb though.
Old May 26, 2005
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
if you get megan racing resonator, you will be able to have cel off with just a small mod that requires a spark plug non-fouler, I did mines that way with nitrous 80 shot and no cel problems. Some people say nitrous damages the stock cat, so buying a megan resonator for cheap wont hurt. Spark plug non fouler is 5 bucks and works good.
Old May 26, 2005
vtecd17's Avatar
Desperate Custom Swapper Speed Freak
vtecd17 is an unknown quantity at this point
im prb going with the HP full racing header wit the high flo cat. that would work perfectaas/
Old May 26, 2005
badodyssey's Avatar
badodyssey is an unknown quantity at this point
I've run nitrous on my 00 odyssey for a few years now with no issues. i'm in the process of adding it to my 03 blown Si....I do have the Megan high flow cat however now...should have no issues.
Old May 26, 2005
How will a hi flow cat effect emissions?
Old May 26, 2005
badodyssey's Avatar
well...i'm going to 'test' my setup at the local BMV soon. If not i'll have to swap the cat every 2 years. as long as they don't do a visual check and you don't have a CEL, you should be ok. I have heard that the Si will pass emmissions even without a cat! we'll see...i'll keep you poseted if I have it done.
it's such an easy swap, at least the megan stuff, that it's no issue for me to do it once every few years!
Old May 26, 2005
Yea dude thanks, I'm curious of the results!
crowtoo
May 11, 2015 06:50 PM
ak
Engine Swaps
29
Jun 18, 2003 07:15 PM
Boosted2k2
Engine Swaps
20
Jun 16, 2003 01:05 PM
civicex2002
Oct 22, 2002 02:03 AM
2k2civicballer
19
Apr 26, 2002 01:57 PM
