RPMs not Getting Above 4,000RPM!?
Old May 18, 2005
Daemones6's Avatar
Daemones6 is an unknown quantity at this point
I just got my set up done (TSI T25BB Extreme with eManage, TurboXS HP Boost Controller, and Apexi Turbo Timer), and everything was great until after I finished running on the highway for about 30 minutes. Then, when I mashed on the gas and the rev got right at 4,000 RPM, it started cutting off and not going above 4,000 RPMs.
I have an auto (go figure), and it is exactly like when I used to rev the engine while in PARK, and it would only go up to like 5,500 RPMs then start fluttering. But I'm on the road this time.
It only does it after I've been on the road for 20 or 30 minutes. Anyone know what it could be?
Old May 19, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
car is in safe mode. any cel???
Old May 19, 2005
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
the ecu may be seein boost, do you have the missing link?
Old May 19, 2005
HondaLuver's Avatar
Its a celebration bitches!
ur car is in limp mode.... look check all your connections again
Old May 19, 2005
andyman97's Avatar
Turbo Guru
If you don't have a cel, you may be getting a fuel cut. Make sure you're supplying the fuel for the turbo in the higher rpms.
Old May 19, 2005
Daemones6's Avatar
I have a cel. I have a TSI kit. I just check the left over parts, and it looks like the shop didn't install the TSI Black Box. Is that what's doing it? Will installing that fix it? What all do I have to wire that too? I need as much info as possible to take to the shop since they didn't put it on anyways. Probably didn't knwo what it was for.
Old May 22, 2005
Daemones6's Avatar
No help here?
Old May 22, 2005
andyman97's Avatar
Turbo Guru
No idea what the tsi black box is....maybe a resistor box for injectors? If you aren't using saturated injectors, you need a resistor box for your injectors. I know nothing about what tsi uses in their kits.
Old May 23, 2005
HyaBoosta's Avatar
well if you have the emenage did you update the settings. sounds like the MAP wire isn't reading right
Old May 23, 2005
2K1Civic17"Gabe's Avatar
yes, thats what causing the crappy driving, CEL, and safe mode. INSTALL IT ASAP BEFORE YOU BOOST. Your MAP is seeing high voltage which is going to your ECU. That can fry your ECU, so dont boost till you get that installed, and the CEL should go off on its own. Good luck, and if you need to know where the wires go to, let me know by PM.
Old May 23, 2005
and just so you guys know, what the black box is, is basically a missing link. You can use one or the other, just so the MAP doesnt see boost. Im suprised your car is even running w/out it. My car didnt want to do anything but die on me.
Old May 23, 2005
Michalo187's Avatar
Abortion Survivor
yeah just your car is running limp mode happened to me because i had no missing link
Old May 29, 2005
Daemones6's Avatar
Had my shop put on the Black Box. Car got messed up. eManage blew, spark plugs fried.
Spoke to Greddy, they said that with the eManage, Missing Link is not needed because there is an option in the eManage that takes care of that. He walked me through reseting the eManage (thank God). Soaked my plugs in fuel injector cleaner. They're fine.
Turned out to be loose wires to my injectors and a O2 sensor popped out. Imagine that...
Old May 29, 2005
Blahman240's Avatar
Touch it... He won't bite, He'll just come at you pretty quick.
Blahman240 is on a distinguished road
I'm going to call rev limiter...
Old Jun 7, 2005
kickoo's Avatar
kickoo is an unknown quantity at this point
Just Unplug The Bloodly Battery And Plug It Back In.....simple.
Old Jun 7, 2005
andyman97's Avatar
Turbo Guru
Well, if he can't get past 4k rpms, don't you think his revolutions per minute are kinda limited there? You're just restating what he's already said and everyone already knows. What he wants to know is WHY his rpms are cutting out on him.
Anyways, yeah, if you don't have anything for the map sensor, you need to put something in there right away. Then, like kickoo said, disconnect the negative terminal from the battery for 60 seconds and plug it back in. Problem should go away after that.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Bruce2
Sep 27, 2015 08:45 PM
speedlever
Sep 24, 2015 07:18 PM
NROD315
Sep 23, 2015 03:46 PM
Juanb24
Sep 15, 2015 12:39 AM
