Crower Releases Stage 2 Cams for D17a2
Old Jun 3, 2005
  #31
goodtimes's Avatar
is this cam the stage two turbo cam or the N/A cam?????
Old Jun 3, 2005
  #32
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
Originally Posted by Redline04
WTF happened to the dyno #s? Guess doesn't really matter cause I jave a DX but I could always head swap. So where are the dyno's.
huh? ... weren't you getting a type s?
Old Jun 3, 2005
  #33
Redline04's Avatar
AKA Mr. 60ft. Not to be confused with Civic_Redline
Redline04 is an unknown quantity at this point
was, but **** happens and lawyers are expensive
Old Jun 7, 2005
  #34
orso's Avatar
orso is an unknown quantity at this point
mota that does look like it is a biatch
Old Jun 7, 2005
  #35
Michalo187's Avatar
Abortion Survivor
We gotta be able to get crower to make them for the lx/dx i know if enough people **** with them they will do it so lets start bothering them with emails
Old Jun 7, 2005
  #36
Michalo187's Avatar
Abortion Survivor
so where can you buy these and how much are they? and where is the dyno?
Old Jun 7, 2005
  #37
se7engen_riDe's Avatar
se7engen_riDe is an unknown quantity at this point
did anybody post up the dyno's yet?? i wanna know how much power gain these things give out.
Old Jun 7, 2005
  #38
365 bucks for the cam, 307 bucks for springs/rods. you can get them at www.crower.com
Old Jun 7, 2005
  #39
djmota's Avatar
It looks like a pain but It can't be that bad. I have all the tools now. The final thing I needed was the air hose from a compression tester to pressurize the cylinder and keep the valves from falling. My boss had one that will work. Now all I need are my cam and spring/ret set. Those should be shipping next week. I expect a 10-15 hp gain from the cam. This gain will multiply under n20. I should be hitting consistant hi 13's with just a 65 shot.
Old Jun 10, 2005
  #40
orso's Avatar
i hope everything works out keep us posted. man i want to know what these cams will do. somebody do it. im broke.
Old Jun 13, 2005
  #41
orso's Avatar
still broke
Old Jun 20, 2005
  #42
jeryltan's Avatar
jeryltan is an unknown quantity at this point
How's the idling? Mine's idling quite erratically.. If you managed to get your's to idle stable, please let me know what was required to get it to do so.. Tks.. I'm running production Stage 2 btw.. And do you happen to know if I can run Stage 2 with stock valve springs and retainers if I intend to stick to my original rev. redline and use a adjustable cam sprocket to lower the power band instead?
Originally Posted by parditty
Hey guys I posted a picture a couple of weeks back of a cam I was installing, it was actually a crower cam that I was beta testing for them. They are now releasing the cam.
My finding with the D17A2 Cam:
Better Rev's over stock, Better mid-range horsepower..
Defiently would recommend a lighter flywheel if your getting a new cam, make sure you replace your vale springs and retainers when you switch cams. Here is the picture below of the crower cam for our cars..
Old Jun 20, 2005
  #43
I bet the idle is bad because not enough air is getting in. I would suggest porting the throttle body (www.maxbore.com) and even raising the idle speed a bit. Yes there is an idle set screw that will work. I have pnp head work and mine is a bit rough around stock idle. When I turn on the a/c and idle rises 100rpm, it goes away.
Old Jun 20, 2005
  #44
jeryltan's Avatar
I've already ported my throttle body.. The idle set screw only goes from 800 to 1500, my mechanic has tried for a pretty long time but he can't seem to get anything in between.. 1500 is a little too much for me You running Stage 2 as well?
Old Jun 20, 2005
  #45
i still have stock cam but i suspect stage1 won't affect the idle much. You should be able to bump the idle a bit more. One secret trick is to play with the tps sensor, but you gotta have screws instead of the rivets. I know maxbore puts screws on if you sent to him. But i don't know much about adjusting the tps.
Old Jun 20, 2005
  #46
jeryltan's Avatar
I thought the idle set screw is somehow related to the TPS sensor thingy?
Old Jun 20, 2005
  #47
no the idle screw just sets how much the throttle plate stays open at rest. The lever just rests on the screw. The tps is what tells the ecu what position the throttle is in. So by moving the whole sensor slightly, it will affect the idle.
Old Jun 21, 2005
  #48
jeryltan's Avatar
Just to side track a little.. Is there a way to tell whether a set of valve springs and retainers are aftermarket or stock just by looking at it? For example, how do I distinguish Crower valve springs and retainers, from stock ones?
Old Jun 21, 2005
  #49
djmota's Avatar
the retainer will be easy they are titanium and bright silver. the springs would be a little hader to tell. They will be stiffer and the stock springs have blue or white paint on one side to indicate intake or exhaust.
Old Sep 19, 2005
  #50
jknudsen's Avatar
MAVS FAN 4EVER
jknudsen is a jewel in the roughjknudsen is a jewel in the roughjknudsen is a jewel in the roughjknudsen is a jewel in the rough
Did this guy ever get his car put back together or dynod?!?!
Old Sep 19, 2005
  #51
djmota's Avatar
sorry no dyno yet but new track times soon.
see this thread
Old Sep 19, 2005
  #52
dezod's Avatar
7thgen Power Maker
see this thread
MOTA is the man. Always willing to defy the odds.
Old Jul 1, 2009
  #53
irish_d17a2's Avatar
irish_d17a2 is an unknown quantity at this point
Re: Crower Releases Stage 2 Cams for D17a2
i'm gunna puke if i don't see the actual power gains from this soon :OP
noob here, been busy racing vdubs, i'm breaking my own rule here and starting to f with my daily
Old Jul 1, 2009
  #54
greeen01civic4d's Avatar
wow, u just bumped a 4 year old thread.....
Old Jul 2, 2009
  #55
D17alltheway's Avatar
D17alltheway will become famous soon enough
fail!!
Old Jul 2, 2009
  #56
pacotaco's Avatar
pacotaco is an unknown quantity at this point
NOTE TO ALL NOOBS STOP BRINGING UP DEAD FORUMS!!!!
Old Jul 3, 2009
  #57
TRIZ's Avatar
^ 56 posts still makes you a noob, noob. =]
Old Jul 3, 2009
  #58
bomerman19's Avatar
bomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond repute
so your basicly saying that my 30 to 40 post on honda tech makes me a noob also?
your starting to sound like a noob yourself Triz you should know better than that. Post count doesn't mean anything.
you have something like 6,600 post and pacotaco has 56 post yet he has done a lot more work on 7thgens then you have
Old Jul 3, 2009
  #59
hahah, pwnd
Old Jul 3, 2009
  #60
TRIZ's Avatar
Your right, post count isnt a sole determinate of newbness.
Anyone notice the tags in this thread include ****, and ARAB?? Odd.
I"m going back to bed.
