turbo spool question
Old May 3, 2005
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
ok, so im going turbo real soon on my d17. im just wondering if i boosted about 8 psi and drove the car daily, what would happen if im in constant boost. Usually, I drive 80-ish and thats like 3.8 rpms already. If i got like 90 ish it will be like 4.2k rpms. What would happen if i turboed? most of my miles are highway miles and im usually at 4k rpms. will my boost spool up the whole time? is there anyway to make boost not spool up during freeway driveS?
Old May 3, 2005
drjvic04's Avatar
drjvic04 is on a distinguished road
...Wow!...
Old May 3, 2005
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
The turbo will not spool as long as the engine is not under LOAD. When an engine is under load or FULL throttle, thats when the turbo will spool. Driving down the highway may make it spole a little, but it wont be enough to cause any complications. Keep the car in vacuum and you will be fine.
Old May 3, 2005
im stock now! T.T
so its basically like nitrous only sprays on wot if set up that way right?
Old May 3, 2005
HyaBoosta's Avatar
not really cause the cars gonna feel alot slower when not under load. but it also depends on what size turbo your using. I think stock NA motors run at about a constant 16 vac. and with my t3/t4 I can keep it at 16vac on the highway at 80 all day. I always try to baby it and keep it about 10vac the most when daily driving. So far it's been 3 months and not a single prob. :knock on wood:
Old May 3, 2005
2K1Civic17"Gabe's Avatar
I have a T25, and it spools up some, but not too much. You can keep it at -18 to -16hg on the freeway. When driving like normal or on idle, it stays at -22 to -20hg or so Id say on the freeway. Occasionally when you go up a hill or something it will spool if your on cruise control. Witha T25 its a lot harder to keep it not under boost I would say. Daily driving (somewhat peppy driving) I usually hit 0psi to 1psi. a lot of times its when I need to get over, or some dic**** doesnt know how to drive. No probs over hear either, yet. I do a lot less freeway driving than stop and go, which sucks. I drive a lot everyday.
Old May 3, 2005
NoFriends's Avatar
I like ruining your threads.
Aye, boost is dependant on engine load. As long as you arent making the engine really "work" you can stay out of boost even if you are past the point where when racing, you would be at full boost.
Old May 3, 2005
civic01vtec's Avatar
yeah, just like everyone else said......you can cruise down the highway at 70 and stay out of boost. If you come to a slight grade or more in the road, your car will be under a load to maintain the same speed, therefore you will be in boost.
Also, boost is throttle dependent. You can ease the throttle and stay in low boost or u can punch it and go into high boost.
Old May 3, 2005
civicskater's Avatar
Chicks dig my scent
i love cruising at 70 and then just slamming it down...lol, sorry, but i just love that feeling. But yes, what everyone said you wont be fully spooled just cruising
Old May 4, 2005
NoFriends's Avatar
Hehe, I love sitting in a gear or 2 higher then punching it and hearing the turbo slowly spool up as it gets into RPM range.
Old May 4, 2005
blouisgod's Avatar
Life Begins > 6800rpms
damn i want a turbo
Old May 4, 2005
Boost_Junkie's Avatar
Boost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura about
when its up that high i mean itll be spinning but wont be throwing back much into your engine until you put load on it...
Old May 5, 2005
yeah, the last few days I drove about 150 miles stop and go. I was barely under boost, I only hit it 2 times when racing. I drove on the freeway a bunch too, the freeway is very easy to keep it out of boost. Just dont step on the gas hard, and you'll be fine. You can bring it up to 6800 rpm's (i have an lx, not sure of ex's redline) in 1st and not hit any boost. You have to learn to go easier on the gas. You dont have to step on it very hard to get the same pickup as before at WOT.
I raced a new Escalade truck and mustang gt. both of them lost. I beat the Escalade at 6lbs, and the gt at 9lbs. The mustang was so mad afterwards, it was great.
Old May 5, 2005
HyaBoosta's Avatar
im sure you could have beat the escalde without the turbo
-HondaFTW-
Aug 30, 2015 10:38 AM
herbiej
22
Aug 23, 2015 01:02 PM
martinsmartin
Aug 15, 2015 07:34 PM
bhollie
Aug 12, 2015 09:58 PM
justcruzin125
Aug 11, 2015 09:09 PM
