Fuel Pressure Reading
Old Apr 25, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
What is the normal fuel pressure reading on the SF Fuel System?
I got a Autometer Electric Gauge (CF Series). It is reading @ 47psi
Anyone know what is the reading b4 SF fuel system and after???
Old Apr 25, 2005
orso's Avatar
orso is an unknown quantity at this point
i want to say about 40
Old Apr 25, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
w/ SF fuel system or w/o???
Old Apr 26, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
bump.....
no body has a fuel gauge???
Old Apr 26, 2005
jwcardy's Avatar
SRT-4 owner with 2MCHPSI
jwcardy is on a distinguished road
when i did the return conversion on my ride, my factory fuel pressure was around 42-45psi...i would think that the sf fuel system would have it raised quite a bit more than that...
Old Apr 26, 2005
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
well if it is a 10:1 FMU the for each psi of boost it would raise 10psi of fuel pressure right???
Old Apr 26, 2005
jwcardy's Avatar
that sounds right...that would be the reason why his gauge is reading 47psi...cause it isnt under boost...that would be his factory setting, not what the sf fuel system is doing...
Old Apr 26, 2005
Yeah, fuel pressure at idle should be the same or near stock....
Old Apr 26, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
at idle is 47psi and at boost it is still 47psi. my gauage does not move at all.
no matter at boost or idle.
I have been boosting at that level (47psi) for 6months. I had a wire loose 2 days ago and it drop to 40psi, so I was wonder is that a stock pressure.
Old Apr 26, 2005
Titleist71's Avatar
Stock pressure is 45 lbs. In 2nd gear, smash the gas to the floor. If the pressure doesn't rise 10:1 or whatever with boost your FMU is junk. You will see the needle move on the gauge. If your in boost at say 5lbs, your fuel pressure should be 95 lbs assuming a 10:1 ratio. 45lbs base+50lbs of a 10:1=95lbs. At 5lbs of boost I would not want to run any less than 85 lbs on the stock injectors. AND no more than 95 lbs. The injectors are crying at this point and don't want to play anymore.
Old Apr 26, 2005
Titleist71's Avatar
Also make sure your fuel lines are hooked up correctly.
Old Apr 26, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
how can i tell if the fmu is good or bad???
Old Apr 27, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
Also should not my motor be gone now? since I been boosting for like 6 months at 6psi+.
Old Apr 27, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
I guess u may be right. I will take some pics later on tommorrow, so you guys can help me on the lines.
Abb0nz
Jun 23, 2015 06:10 PM
mrcell24
May 19, 2015 10:02 AM
werdnahall
May 17, 2015 11:37 AM
MooCoW
Nov 15, 2001 10:58 AM
