Cost of a K20A swap
Old Apr 24, 2005
bgoetz's Avatar
bgoetz is an unknown quantity at this point
Cost of a K20A swap
I have been researching and am thinking around 7K if I DIY and 8K if I have a shop do it. Is this reasonable or am I still thinking to low?? Note: that it is the K20A not the A2, I really think that it would be worth the extra $ to have LSD and 20hp.
Old Apr 24, 2005
ajhdragon's Avatar
7thgens official a$$hole
sounds about right to me.
Old Apr 24, 2005
doubledeuce2k2's Avatar
you could probably get it for that price.
or just wait for my to sell my swapped civic in the not super distant future.
Old Apr 24, 2005
bgoetz's Avatar
you dont have the k20A do you?? I thought you had the A2. Anyways the entire reason that I am doing this is because I can't get rid of my car for a good price so I am going to keep it. If I was going to get a new car it would be a S2k
Old Apr 24, 2005
k20a2. cams are $400, get a reflash, and you're almost there. so $1k. i can't very well trade in my car, and it's not paid off, so that's my problem.
Old Apr 24, 2005
civic01vtec's Avatar
i agree 100%......obviously if you have boost in your future, then the a2 would be a better option.
Old Apr 24, 2005
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
I think your going to spend a minimum of 8k for the engine. thats the range i calculated it to be with the lsd and type-r engine k20a. Id rather pay for the type-r too
thats with all the little extra stuff you will need to buy during your swap.
Old Apr 24, 2005
Wolfgang5884's Avatar
Damn thats a lot of money, is it really worth it
Old Apr 24, 2005
im stock now! T.T
yeah if you really want to go all out with a civic. IMO i think i would get another car instead of spending that much to build a tight *** sleeper.
Old Apr 26, 2005
bgoetz's Avatar
After more research I am thinking I can get it for 8K installed if I did it myself it would be about 1K less. The engine sells for an average of 5,500 compared to the type S that sells for 3500-4000. I have also decided that due to the fact that I can't get rid of my car unless I give it away I am going through with it and am going to pay extra to get the shop to do it. I think it will be one badass civic and with a couple of bolt-ons it can easily hit mid 13s
Old Apr 26, 2005
bgoetz's Avatar
my only concern now is that after alot of $ and work I have the car handling like a dream, but the extra weight in the front is going to through off my spring rates and I may have to get different springs for my Teins.
Old Apr 26, 2005
ThsUserNmIsDumb's Avatar
Currently boosted at 0 psi.
ThsUserNmIsDumb is on a distinguished road
Ask aznboysrfr... I have this gut feeling that he might know...
Old Apr 26, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
;P
should be right around $7k if you DIY and shop around
5500 engine
300 subframe
200 si axles
500 mounts
300 (?) hasport wiring harness
Old Apr 26, 2005
^ He's like Batman.
Old Apr 27, 2005
C Orndorff's Avatar
Once boosted now i-VTEC
C Orndorff is an unknown quantity at this point
I just did a k20a in my car. I got the whole swap for $4400 (but this was discounted, threw a friends account at H motors.com) then I sold the 5 lug axles and put in 94-01 Integra GSR axles (fits great) I went with the GSR ones because they are only $120 for both at Napa. Vs. 02-03 civic si or a 5 lug swap (more $$$). I mostly see k20a swaps go for 5500-6300. The usually have everything you need. Also Hasport mounts are easy to get off eBay for $375-$475 (new) I got mine for 400 (new) on eBay.
Also you could do what my buddy is doing. He got a k20a3 swap off eBay for $2000, everything he needed, for 2k. And only 7k miles on it. He is going to drive that until he gets some more cash, then he is going to swap the pistons, crank, final drive gear and head. Total he has priced those parts at about $1500 (some used some new) and k20 lsd at $500 when he dose all this he will have a k20a at only 3500-4000 (but only 5 speed but with gears 1-3 the same as the type r)
Old Apr 27, 2005
C Orndorff's Avatar
Also all my labor was free because i did it.
Old Apr 27, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
^ perfect example of somebody who shops around ... minus the discounted motor. not all of us can get a price like that
Old Apr 27, 2005
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
What about using a k24 block, would it be pricier, if say you use a diferent head like a k20a3 or a2 one, since you have to switch the ecu too,
Old Apr 27, 2005
HondaLuver's Avatar
Its a celebration bitches!
interesting
Old Apr 27, 2005
HOndaluver what would the advantage of using the k24 form a crv be intead of a tsx one??
beside cost...
Old Apr 27, 2005
C Orndorff's Avatar
The TSX one has higher compression pistons, that makes more power. The only advantage of useing a CRV, Accord, Element Block is cost. The TSX has the advantage in power.
Here is a Compression Ratio break down of all the K motors.
DC5 Type R K20A - 11.5:1
RSX Type S K20A2 - 11.0:1
RSX/Civic Si K20A3 - 9.8:1
Honda CRV K24A1 - 9.6:1
Acura TSX K24A2 - 10.5:1
Element K24A4 - 9.7:1
Old Apr 28, 2005
Also the torque curve on the k24a1 is more on the lower rpm's, and the k24a4 makes torque on the higher rpm's
Old Apr 28, 2005
bgoetz's Avatar
Did you guys that have done this have to change the springs to ones with higher spring rates??
Old Apr 28, 2005
it's not the spring rates that matter so much. but as a coincidence, rsx springs have higher rates. used springs can be had for like $100 or less. or buy stock type s springs for real cheap as a holdover for coilovers.
Old Apr 29, 2005
so what would prevent the car for going lower once you do the swap??
Old Apr 29, 2005
bgoetz's Avatar
I already have tein coilovers so I am assuming that I have to buy different tein springs.
May 4, 2016 07:14 AM
Kyle Cargazm
Jul 16, 2015 02:06 PM
Star1967
Jul 14, 2015 09:43 PM
manfredww1
Jul 12, 2015 07:31 PM
SpecialRequest
Jul 7, 2015 07:52 PM
