fuel problems
Old Apr 27, 2005
mallison's Avatar
mallison is an unknown quantity at this point
fuel problems
i cant get enough fuel, it was doing fine for a while and now if i boost it the fuel will fall off after a lil while, anyone know if i can get or where i can get a better fuel pump and so on?
Old Apr 28, 2005
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
what type of fuel system do you have?
Old Apr 28, 2005
HyaBoosta's Avatar
x2^ your best bet is to get the walbro pump and just trim the cage a bit. It should fit in. But it sounds like your pump is bad or if you have a fmu that it may be bad
Old Apr 28, 2005
Ahtasham's Avatar
Ahtasham is an unknown quantity at this point
Would the in-tank walbro pump work with the SF's fuel system? Has anyone tried this?
Old Apr 28, 2005
HyaBoosta's Avatar
I would Im agine it would work with it. I don;t see why not. You won;t be able to adjust the FP though. you would Have to eliminate the FPR on the assembly.
Old Apr 29, 2005
mallison's Avatar
right now all i have if factory and it worked for a lil while but slacked off all of a sudden, is there any specific one to get? or any complete systems out there
CarStuff
Dec 6, 2020 12:52 PM
juror
May 26, 2015 06:35 PM
mrcell24
May 19, 2015 10:02 AM
superstanko
Apr 28, 2015 04:38 AM
dooner24
Apr 14, 2015 07:51 PM
