Wiring Diagram for TSI Unit
Old Apr 11, 2005
KalliGarri's Avatar
A.K.A BlackCar --- Not From Califorina!
KalliGarri is on a distinguished road
For those who are having trouble with the TSI Fuel Unit, try this out and see if it helps any.
1. Gray-RPM Signal.. i connected that to the blue wire that is in the hood by the negative terminal
2,3,4,5. Brown- connect that to the negative wire for the injector.. other side is connected to 12 volt postive battery
6. Green- No Connection
7. Black- Ground
8. Blue- Hand Brake- I took off the middle console and theres this little clip by the hand brake that is connected to a metal piece, and there are 2 wires leading from it, I simply took off the plastic clip, stuck the wire in the clip, and connected it back to the metal piece.
9. White- Ignition on 12V. Under the stearing wheel, there are thick wires, i connected this to the Black with yellow stripe wire.
10. Red- Battery 12V- There is the fuse box in the hood, and in the row closest to you when your infront of the car are 2 large screws, they are 12V sources, i unscrewed them and stuck the wire in there.
11. No Connection
12. Connect to ACC on 12V- Under the stearing column, it is the Black with Red stripe wire.
Old Apr 22, 2005
2K1Civic17"Gabe's Avatar
I am going to go retry this right now. My 3rd unit still isnt working. damnit
Old Apr 23, 2005
KalliGarri's Avatar
hey do me a favor and take a picture of EVERY one of ur connection so i can see how u did it, and send it to me through AIM
Old Apr 23, 2005
Damn, I didnt see this in time. I still have a few more to do. I can show you how I wired them. Do you want to see the spot I tapped into, or how the wires are tapped into? Ill go arond and show you where I hooked up all the wires.
The 12v power (red wire) I need to hook up to the ignition harness. I am thinking it is the plain white wire. Ill find out.
Old Apr 23, 2005
Daemones6's Avatar
Daemones6 is an unknown quantity at this point
eManage man. Hey. At least your BOV is working...
Old Apr 23, 2005
hehe, yeah, I love my BOV, too. Sounds freakin clean. I am gonna be getting eManage for my B-day. I dont want to keep setting my ICU everytime I get in the car though, until May 26. I will have eManage by than.
Just rewired everything, and still doesnt work, I have 2 of their ICUs and none are working. I dont know where the wiring is messed up. Everytime I redo it though, I see things that are wrong. (i didnt wire). BUt its all being fixed as I find it .
Old Apr 23, 2005
KalliGarri's Avatar
No, the 12V power source, connect it to the fuse box by the engine bay, its those 2 screws, use the one on the LEFT. let me knows what happens after that
Old Apr 23, 2005
Left, cool, ive been using the right. Ill post back in 10 mintes. I have to try it out a few times.
Thanks a lot!!
Old Apr 23, 2005
nothing...... POS POS POS POS POS POS POS POS POS POS POS.
I hope no little kids are around me while Im working on my car. Im screaming cuss words so f***in loud. IM not joking either. I swear they can hear me 10 houses away.
This sucks, screw this, screw civics, screw turbos, screw automotive performance, screw everything with cars period!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
PS: any more help? I cant keep setting my car up, Ill kill somebody
Old Apr 24, 2005
KalliGarri's Avatar
e manage?
Old Apr 24, 2005
My birthday. Maybe a week or two before may 26 I can get an early present. (or 4 or 5(harnesses))
Old Apr 25, 2005
I am gonna try changing the parking brake wire. lol. I know it probably wont make the biggest difference, but I wast old that it should go in like yours, into the actual clip. So I will see if that works, but that should have nothing to do with it resetting, only with the turbo timer safety. and that works fine for me.
I can hook up one of the wires to a constant, and have it on all the time, but that could drain my battery. Is anybody elses on all the time? It wouldnt think it should be, and I doubt the turbo timer would even work.
4 banger
Jun 5, 2015 01:44 AM
darwin-t
Apr 18, 2015 09:29 PM
supsoop
Jan 23, 2002 05:35 PM
stpfrancois
Jan 19, 2002 08:53 PM
Jimmy24
Nov 27, 2001 05:44 AM
