K24 Em2
Old Apr 10, 2005
  #31
ncirom2003's Avatar
so if the k24 is soooo much cheaper and its real torquey why is nobody else doing this swap???
Old Apr 10, 2005
  #32
TemjinX2's Avatar
some people say the k24 is pretty much maxed out, but the k20 has a lot of potential. The new hondata flash for the k24 looks promising.
This site has lots of good info on the difference's between the k24 and k20.
http://www.k20a.org/forum/
Old Apr 10, 2005
  #33
acidbaby's Avatar
The Beez Kneez
because it requires alot more customization....
Old Apr 10, 2005
  #34
ncirom2003's Avatar
^^^ thats what i figured but at one point or another the k20's also required alot of customization im sure, so why not do that work to make the cheaper engine easier to install. but temjin makes good point
Old Apr 10, 2005
  #35
acidbaby's Avatar
The Beez Kneez
the k20 has a **** load of aftermarket support already and it is still a new engine.
ive seen frankenstiens with a k24 block and k20 head i think or maybe it was the other waaay around. it was for a full race setup though.. its been a while since ive been here so dont quote me on that
Old Apr 10, 2005
  #36
TemjinX2's Avatar
i read the faqs on the k20 site, basically if your going to go the frankenstein route with the k24, you have to build up your engine because there some conflicts since the k24 and k20 are designed slightly differently.
In the end, if your happy with 200hp and dont really plan on tuning it anymore, i think the k24 is a good choice because of the cheap price. If you want to tune your car after the swap, the k20 is a better choice, since there's already a huge aftermarket support and its most designed for high power output, then the torquely k24.
I'm betting that the new 8th si is going to use a k20a2, so when it comes out the price of the k20 is going to drop. The Si is more of a main stream car then the rsx so more people will be driving SI's then rsxs, so more people will crash them. Thus add more k20's into the market. Hopefully in a yr or two the price of k20's will go down and be closer to the price of b18's.
Old Apr 10, 2005
  #37
ACURAwerx's Avatar
ACURAwerx is on a distinguished road
is there any room left in there to turbo or any thing?
Old Apr 10, 2005
  #38
HondaLuver's Avatar
Its a celebration bitches!
the aftermarket parts for the k20 are basically the same as a k24. just a tiny diffrence. intakes fit, the exaust has to be a little longer... but you can use hondata on both, they both use the same sensors... you can exchange exhausts/ intakes/ it has the basic same parts of a k20 jjsut maby a little bigger or longer internals.. blah blah blha
Old Apr 10, 2005
  #39
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
The only major difference is the deck height.
Old Apr 10, 2005
  #40
ojay's Avatar
ojay is on a distinguished road
****ing nice. please keep us updated.
Old Apr 10, 2005
  #41
Alex1's Avatar
yeah what he said, cuz if a 24 goes in my car u better believe that **** is getting boosted!
Old Apr 11, 2005
  #42
KnocturnalEM2's Avatar
I am your Mom's Hero!!
WOW...looks stuffed for sure!! Good job tho!! Very nice install!!!!!
Old Apr 11, 2005
  #43
acidbaby's Avatar
The Beez Kneez
yeah it would be hard to fit much more under there...
Old Apr 11, 2005
  #44
Wisper's Avatar
Wisper is an unknown quantity at this point
Originally Posted by Nerologic
Its a accord k24 (so its conventional) motor and a k20 tranny...
As for a tight fit, it was because the k24 manifold is 2 times the size as the k20 manifold.
As for cost u have to call "B series" the number is 760 752 1898, if u gusy want to check it out and are local (San Diego/ SoCal) call and check out the car..
If you want to make some more room, like another person said already, you can make a bit more room with using the K20 intake manifold. According to other people on K20A.org it should be shorter.
Old Apr 11, 2005
  #45
Skunk2ner's Avatar
Skunk2ner is an unknown quantity at this point
boost is nice on the K24. i read an article on one of the first TSX's to get a turbo as a project car. it was pushing 385 hp with no other mods if i remember correctly.
Old Apr 11, 2005
  #46
AzNmiKex215's Avatar
2k1civic.com O. G.
i love how K20A.org has a forum that says "1992+ Civic EG / DC2 / EK / EP3 K-Series Swap" and Doesnt even list the EM2. I mean the EM2 was MEANT to take a K series. atleast moreso then any of the previous Gen civics or Integras.
It just shows how everyone really doesn't recognize us
Old Apr 11, 2005
  #47
ojay's Avatar
^eh, screw 'em. what's new anyways?
a solution is for us to get more swappers and post bomb that forum :devilish laugh:
Old Apr 11, 2005
  #48
ACURAwerx's Avatar
^^ they are just jealous
Old Apr 11, 2005
  #49
ren808's Avatar
ren808 is on a distinguished road
Originally Posted by robbclark1
Give us more info!! Specs, cost, time spent, problems, positives, time slips...anything!
^^^^^SECOND THE MOTION!!!!!!
Old Apr 11, 2005
  #50
HondaLuver's Avatar
Yup.... Well a k20 manifold on a k24 doesn't make a diffrence. There is still about half a inch clearance between the mani and the upper radiator support
Old Apr 11, 2005
  #51
Rufus's Avatar
you tellin me I'll have to lift the engine to get that manifold off?
Old Apr 11, 2005
  #52
Nerologic's Avatar
Nerologic is an unknown quantity at this point
the k24 was ALOT harsder to install then the K20. The person did it because of the $$ factor he saved about 1500 for going with the k24.
the head will be replaced with a built k20 head that is in the process of machine shop work rigth now.
its running on the stock EM2 ecu right now awaiting KPRO
as for teh k20 head on teh k24 block, its pretty much plug in play if u are familiar with a B series motors, its liek an LS-V, only easier
Old Apr 11, 2005
  #53
HyaBoosta's Avatar
how does the d17 ecu support that motor?
Old Apr 11, 2005
  #54
Nerologic's Avatar
it turns it on and does teh job, but we are not going to rev it out with it, its just to get the cars started and work out the bugs
Old Apr 11, 2005
  #55
TemjinX2's Avatar
You should get the hondata for the k24. It has nice gains.
http://www.vtec.net/articles/view-ar...icle_id=339233
Old Apr 11, 2005
  #56
acidbaby's Avatar
The Beez Kneez
indeed kepp us posted this going to be a monster thread...
sticky eventually?
Old Apr 11, 2005
  #57
PunkingCivic's Avatar
I need TP for my bunghole
cool biz
Old Apr 11, 2005
  #58
Ellocodetroit's Avatar
The Declaration of Independence was written on marijuna paper
Ellocodetroit is a jewel in the roughEllocodetroit is a jewel in the roughEllocodetroit is a jewel in the rough
subscribing. Nerologic where exactly in So Cal are you located?
Old Apr 11, 2005
  #59
ncirom2003's Avatar
so you have a k24 with k20 tranny d17 ecu and just about everything else is d17(exhaust hole way)
Old Apr 12, 2005
  #60
Nerologic's Avatar
Northern San Diego
as for hondata, its getting Kpro (which is hondata) :wink:
