Leaking Fuel Solenoid
Old Mar 31, 2005
scansel912's Avatar
scansel912 is just really nicescansel912 is just really nicescansel912 is just really nicescansel912 is just really nice
Put my nitrous kit on today and intially it was spraying fuel out by where the line connects with the fuel solenoid. So I took the solenoid off, took off the fitting and re sealed it with thread sealer and got it as tight as I could. I then tested it again and no spraying. So was driving around to make sure everything was ok then popped my hood open to check the solenoid and it seemed fine. I touched the fitting with my hand and it was wet with gasoline. I think its leaking wear the hose connects the fitting not where the fitting goes into the solenoid but I could be wrong. Anyone have this problem or know how to fix?
Old Mar 31, 2005
jwcardy's Avatar
SRT-4 owner with 2MCHPSI
jwcardy is on a distinguished road
well, what i would do is have someone rev the car some while you stood outside and visually inspected the problem while the car and fuel system is under a load...see if that helps
Old Mar 31, 2005
scansel912's Avatar
Yes Ive done that but the leak is so small you can't see anything coming out anymore. But everytime I touch the fitting, its wet with gas...
Old Apr 1, 2005
Killacamshaft's Avatar
G'z UP
Killacamshaft has a little shameless behaviour in the past
when i installed my nitrous i had the same problem all i did was retighten everything the clamps tht go on the gas line u had to tap may not bo tight enough
Old Apr 1, 2005
djmota's Avatar
I would pull off the sol. take off the line and fitting check and clean the threads and reseal and tighten everything down once more. I would not feel safe until everything stayed dry. You can check for leaks at idle as the fuel pressure is the same no matter what rpm.
Old Apr 1, 2005
scansel912's Avatar
went to jegs today and bought a new AN fitting. Put the new one back on and it has no leaks at idle. I will test my nitrous today and see how everything goes. Thanks for the help.
usajags84
May 30, 2015 06:49 PM
superstanko
Apr 28, 2015 04:38 AM
JoeB16
61
Oct 16, 2003 07:58 PM
Red2k3Civic
Feb 15, 2002 09:44 PM
Lightman
Nov 10, 2001 06:44 PM
