Thermostat & thermo switch for turbo?
Old Mar 30, 2005
supermex's Avatar
supermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to all
Just wonder if any one knows if we can get a colder thermostast and switch that will fit our cars?
Old Mar 31, 2005
MadWheel's Avatar
Premium Boosted Member
I bought a nippon thermostat for my civic which replaced the Denso one... I'm not sure if it's any cooler than the stock one, but it worked out well, and it seemed to be built well. It's a cheap parts, like 22 bucks or so, so it's worth a shot.
Old Mar 31, 2005
tfnaaf's Avatar
BLDNPSI Mod
i remember reading something about some JDM company that makes a fan/temp switch for a honda . But not sure if it would work on ours. Im not familar with what turns our fan on. Is it the temp sensor or the computer that trips it?
Old Mar 31, 2005
TheSmuggler's Avatar
Hmm, arn't ours the same as the older gen civics? I know spoon makes one
Old Mar 31, 2005
thiscrackerntam's Avatar
thiscrackerntam will become famous soon enoughthiscrackerntam will become famous soon enough
That sounds like you replaced one genuine honda thermostat with another. Why would it be worth a shot without knowing if theres any difference between the two? If they're the same thats just wasting 22 bucks.
Old Mar 31, 2005
jwcardy's Avatar
SRT-4 owner with 2MCHPSI
jwcardy is on a distinguished road
i have been told by several people, that factory is the best
Old Mar 31, 2005
^^^Stock honda parts are way better than a lot of people realize... At the very least, I advise highly not to run your engine with a modified oem thermostat and not to run your engine without thermostat at all. This might be a no brainer from some, but there are actually quite a few people out there who believe that doing one of those two things helps keep your engine run cooler which is wrong. I've actually read that it DOES help on atleast one website that I've read and thats completely obsurd.
Old Mar 31, 2005
jwcardy's Avatar
yeah, and i wasnt just saying that to be saying it...i have heard that from many honda techs that i know...i will be leaving mine stock, and i am shoot for 275+whp with my new setup
Old Mar 31, 2005
supermex's Avatar
60k miles on it it will be a good try any way.
Spoon makes this parts for $ 90.00 a piece.
I was wondering if Dezod, Street Level may be Robear had an alternative?
Old Apr 29, 2005
mclean987's Avatar
mclean987 is an unknown quantity at this point
im looking for a performance thermostat that opens at a lower temperature, i found some jackson racing ones for older civs but i dont know if they will fit, i also wanna buy a performance fan aswell and do anything possible to make my car run cooler
Old Apr 29, 2005
mclean987's Avatar
oh yeh where can i find a performance radiaor cap aswell
Old Apr 29, 2005
HyaBoosta's Avatar
anywhere sells the rad. cap.
I just got a bling @$$ ARC rad. cap so I can stunt on everyone. G-G-G-Gunit!
Old Apr 29, 2005
Ellocodetroit's Avatar
The Declaration of Independence was written on marijuna paper
Ellocodetroit is a jewel in the roughEllocodetroit is a jewel in the roughEllocodetroit is a jewel in the rough
Kingmotorsports.com That's where I got my Mugen rad cap. Robear also has them.
Old Apr 29, 2005
mclean987's Avatar
did the mugen cap make a difference ?
Old Apr 29, 2005
mclean987's Avatar
so it fits right? do you know if the fan switch and thermostat will work aswell they say for 99-00 civic ?
http://kingmotorsports.com/category....ategory=Engine
Old May 1, 2005
supermex's Avatar
The cap is not a problem.
A colder thermostat will be very usefull specialy on the south when is very hot.
I don't doub the honda parts quality they are great when the car is stock.
But when running turbo is good when the termostat open early.
I belive the stock opens at 200 degree.
I could be wrong. any one?
Old May 1, 2005
mclean987's Avatar
kool i just wanna know if the thermostat and fan switch willwork on our 7th gen
Old May 1, 2005
I don't know if it would fit. I got the the cap for looks.
Old May 2, 2005
supermex's Avatar
I have replaced the old thermostat and switch, I'll have to take it to a place that sells the older version civic parts and see if they look similar.
I just want to know at what temperature our thermostat opens so i have somthing to compare it too..
Old May 3, 2005
mclean987's Avatar
what kind of fan switch and thermostat did you put in ?
Old May 3, 2005
supermex's Avatar
Stock.
The fan switch problem can be solved just by addind a fan on fron of the A/C condenser and run it from a thermoswich so the fan will activate sooner than stock.
The trick is to get the thermostat that open sooner than stock so the car will stay cool while boosting eg: is stock opens at 200 degree the water is allready hot whenit reaches the radiator and will take more time to cool.
The motor performace will decrease and eventualy will get damage.
If the thermosat opens at 150 degree the water will reach the radiator before it gets too hot and will keep the car running a bit cooler, and with the help of a fan and a good radiator you'll be able to boost longer without reaching a boiling point.
Old May 3, 2005
2K1Civic17"Gabe's Avatar
pics?
Old May 3, 2005
supermex's Avatar
Originally Posted by 2K1Civic17"Gabe
pics?
I haven't done the fan yet as soon as I do i'll post pictures.
Is a very easy mod just need to know how to wired the relay for the thermoswitch you can buy this parts at any autoparts just need a thin fan maker sure is a pusher fan.
I have one in my garage I used once on my big van and workerd fine for 2 years.
What I realy want is the thermostat and I can seem to find it or find anyone that knows where to get one
Sarahwv2910
22
Jun 17, 2015 12:35 PM
Supramk3
Jun 11, 2015 11:13 AM
brian257
Jun 4, 2015 08:17 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
JoeB16
61
Oct 16, 2003 07:58 PM
