cant remove bolts for manifold
Old Mar 28, 2005
ShadyImprtracer's Avatar
ShadyImprtracer is an unknown quantity at this point
i cant remove the stock bolt, right in the center, its stripped... from the headers where the mani will be placed as we are in the process of installing my turbo. did anyone else have this problem and how did u take them off?
Old Mar 29, 2005
Alex1's Avatar
u drill it out... start with a small bit
Old Mar 29, 2005
civic01vtec's Avatar
if it is stripped, it still should come out. You will then have to buy a tap and re-thread the hole.
if you can't get it out, you will have to buy a reversed drill bit to drill it out
Old Mar 29, 2005
bradmanuwf's Avatar
bradmanuwf will become famous soon enough
are talking about the one on the bottom row in the direct center of mani? or a bolt on the top row? if its the top row, u'll have to drill it out. if its the bottom row, u'll have to get another stud to put in there and good luck getting the old one out.
cukaracha
30
Jul 26, 2015 12:01 PM
Ccoop87
Jul 9, 2015 03:26 PM
trellex
Electrical
Jul 9, 2015 12:01 PM
ballmich
Jul 9, 2015 11:59 AM
hayden55
Jul 8, 2015 11:38 PM
