Alcohol Injection causing Turbo Lag ???
Old Mar 15, 2005
Ahtasham's Avatar
Ahtasham is an unknown quantity at this point
Ever since I got the SF kit I have been running low 6 psi and high 8 psi without any problems at all. In fact, I must say that the overall performance have been outstanding (T3 Super 60).
Two days back I decided to hook up the alcohol injection and go for 10 psi. I used the washer fluid bottle and 100% pure methanol for the application. I also got an LED connected to the alcohol sensor and got it set up at 8 psi. But somehow, the results are not as good as I expected.
First of all, the 2 psi gain that I get from switching from 8 to 10 psi, does not seem to be as strong as the 2 psi gain from 6 to 8 psi.
But the real problem I am getting now (after alcohol injection) is that there is a big amount of lag. The first two gears are somewhat ok (with all the tire spin), but the moment I shift to third, the car gets 'lifeless' and then when the rpm crosses 6000, it starts flying ..... and then the fourth gear goes just fine.
Any ideas on what could be causing this ...... ? Any solution ???
Old Mar 16, 2005
guns's Avatar
Skyline R33
guns is an unknown quantity at this point
Old Mar 16, 2005
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
When psi is the alcy being activated?
Old Mar 16, 2005
iamboo's Avatar
Retired - SoCal FI Mod
8psi he said... that's really not the problem here..... you can try and increase the amount of boost to 10psi on the switch to see if that does anything....
does your check engine light flash at all when the alcohol is being fed into the throttle body?
you said the car lagged a little when boosting running pure methanol, try running a 75% to 25% water mix instead... pure methanol will actually reduce performance using alcohol....
i think another problem you might be having is that the nozzle that sf gave you might be too big... meaning there might be too much alcohol being fed and causing the car to run way too rich.... if you pull the peice out that screws into the elbow... you should see a copper fitting with a small hole on the tip... take that to a place where they sell welding supplies... ask them for that same fitting but tell them that you want the hole on the tip of the fitting to be smaller and they should hook you up...
hope this helps...
Old Mar 16, 2005
Ahtasham's Avatar
hope this helps...
Thanks buddy ... I'll try both the things you said. And no there is no engine light whatsoever ....
Old Mar 17, 2005
turboengnr's Avatar
DONT PANIC
too much alcohol. The kit uses Tweco Mig welding tips. The one you got was probably a .035" nozzle. Try a .030" or a .025" tip. They just screw in. Make sure you use lok tite.
you can get them at any welding shop.
Old Mar 17, 2005
Ahtasham's Avatar
Thanks ... I am going to try this out over the weekend.
Old Mar 21, 2005
pnoyster2k1cvic's Avatar
Balut Eating Champ
so how did it went? I wanna know, I might be getting a kit if nobody buys kit
Old Mar 21, 2005
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
Remember, lag and boost threshold are completely different things.
Old Mar 22, 2005
Ahtasham's Avatar
I didnt get the time to work on the car So now I'll have to wait for the next weekend ........
Old Mar 29, 2005
Ahtasham's Avatar
Ok I switched from pure methanol to 50/50 water methanol .... still no difference. Now the only thing left is to reduce the amount of mixture being injected. Hope that solves the problem, otherwise its bye bye to the Alcy Injection system!
jordan1794
General 8th & 9th Gen
May 11, 2019 08:59 PM
15EXCoupe
Jul 30, 2015 12:59 PM
jzhartman
22
Jul 23, 2015 10:42 PM
ShaneShepley
Bolt-on Engine Performance
Jul 21, 2015 05:25 AM
Theshwartz35
Jul 18, 2015 10:49 PM
