A L C O H O L I C
Old Mar 28, 2005
  #31
C2i0v0i1C's Avatar
SuperMODrizd
still wouldnt do it, just build it with the right parts right fuel, right tuning, then u dont need to have injection of anything
Old Mar 28, 2005
  #32
thiscrackerntam's Avatar
thiscrackerntam will become famous soon enoughthiscrackerntam will become famous soon enough
Originally Posted by pnoyster2k1cvic
^^^ FIY---if you're NA yeah i agree... don't even bother... this is for Heavy Mods and Boost...
^^^FYI, I'm soon to be boosted and dont worry, I wont bother because thats my preference.
Old Mar 28, 2005
  #33
pnoyster2k1cvic's Avatar
Balut Eating Champ
cool man... nice to see more and more 7thgenners are boosted!!!
Old Mar 28, 2005
  #34
civic01vtec's Avatar
well, it's all about making power. Like i said, there is nothing wrong with a properly tuned water injected motor. Water cools the air intake charge by a avg of 65degrees. You could increase your timing and use water injection to cool the intake charge and i bet you could get 260whp from your car.
Old Apr 11, 2005
  #35
Captnplnet's Avatar
Captnplnet is an unknown quantity at this point
also if you live in states like CA with terrible gas (91 octane) alcohol injection can help prevent detonation as mentioned before and can also provide more air to the fuel allowing you to run higher psi. the water injected, when hot enough becomes steam and acts like a steam cleaner that can reduce carbon deposits in the engine as well. i aslo believe it can also help save on gas mileage? but i may be wrong there.
Old Apr 11, 2005
  #36
Balut Eating Champ
^^^hehehe that, and when you floor the damn thing making 200+ WHP scrapes the carbon deposits off!
Old Apr 11, 2005
  #37
C2i0v0i1C's Avatar
SuperMODrizd
still wont do it
Old Apr 11, 2005
  #38
Balut Eating Champ
here's more, it will help you understand a bit more about alcohol injection... CLICK>>> http://www.geocities.com/rad87gn/tech/alcohol.html
Old Apr 11, 2005
  #39
C2i0v0i1C's Avatar
SuperMODrizd
"Alcohol sprayed directly into the charged air stream has a substantial cooling effect and acts kind of like an inter-cooler."
i didnt make it past the first sentence and closed the window.
Old Apr 11, 2005
  #40
Balut Eating Champ
just some of the info... not to change your opinion about it, and not completely close the door on it... but embrace it a little bit...
Old Apr 11, 2005
  #41
C2i0v0i1C's Avatar
SuperMODrizd
if it works for u, more power to u, its not for me
Old Apr 12, 2005
  #42
hater
Old Apr 12, 2005
  #43
C2i0v0i1C's Avatar
SuperMODrizd
hater
who are u talkin to
Old Apr 12, 2005
  #44
Balut Eating Champ
nevermind guys, this thread has served it's purpose... i just wanted to show off what I had installed and what I thought about it... mod close pls...
Old Apr 12, 2005
  #45
Jhonda's Avatar
Jhonda has a little shameless behaviour in the past
I am using this also on my JRSC svt focus. I am running 9lbs now with the methonal injection. I am using a mix 50/50.
I for one did not adjust the timing like you can to gain more horsepower. The reason I did it is for the safety factor. The supercharger on my car has no way to inter or after cool the charge with a Air to air or air to water kit.
Most people see a 10whp gain just by adding the kit. I didn't because I am still having some timing issues. (stupid varible cam timing) I will be eliminating this hopefully this weekend and will give yall some before and after numbers. If you want them.
I will stand by this product 100%
There is alot of imformation throughout this website www.snowperformance.net
Old Apr 12, 2005
  #46
zachgeyer's Avatar
sweet
