e-manage gurus...big problem
Old Mar 24, 2005
fi dx's Avatar
fi dx is an unknown quantity at this point
Unhappy e-manage gurus...big problem
when starting to tune today....i had the car just idling setting up the real time display stuff to make a run....at idle the rpms read around 5000....with just a little gas it was off the chart past 8000 ....i couldn't think of any reason this would happen beside the wiring...checked that and it was all good....with just idle revs it is very sporatic...but when the car is under load....it is a little more tame...but still way off...any ideas?
Old Mar 24, 2005
Titleist71's Avatar
check settings? 4-8-C for EX, look at the FAQ for the wiring and setup info.
Old Mar 25, 2005
dezod's Avatar
7thgen Power Maker
Is the tach reading 5K or the E-Manage?
Old Mar 25, 2005
HyaBoosta's Avatar
Sounds like you might not have set your TPS.Did you tap the wire for the rpm in the diy or did you use the blue wire on con. D?
Old Mar 26, 2005
fi dx's Avatar
the e-manage is reading 5000
as far as the settings...i pretty much used the e-manage faq to install it so i believe teh TPS is the grey wire...my jumper settings are 4-8-C
any other ideas?
Old Mar 26, 2005
dezod's Avatar
7thgen Power Maker
any other ideas?
did you calibrate the throttle?
Old Mar 26, 2005
HyaBoosta's Avatar
you need to take the brown rpm wire from the main harness and connect it to the blue rpm wire on con. D. the wire they say to connect in the DIY is the Crank Position Sensor. And make sure you calibrate you TPS.
Old Mar 27, 2005
fi dx's Avatar
i did calibrate the throttle on the e-manage
after messing with everything i could think of i decided to pull all the wiring out again and i did have the brown wire connected to the blue wire...however when i pulled it all out it looked as though maybe a bad connection? i don't know if that would make my rpms on the e-manage go so high...but i decided to re-solder it just to be sure
i'm hoping that's the right thing...cuz i had it all tuned and running nicely and now it runs so rough i can't even drive it without going wayyy lean or have it stalling
Old Mar 28, 2005
bakablo's Avatar
bakablo is an unknown quantity at this point
your e-manage is not installed correctly I had that too...
Old Mar 28, 2005
fi dx's Avatar
bakablo...what did you do to fix it? or what was teh problem? i had it working fine before and it was just randomly doing this one day
Diznavis
Jan 25, 2002 11:25 AM
TeamStylesRacing
Jan 20, 2002 08:38 PM
delacampos
Transmission
Jan 2, 2002 02:06 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
Flatlander
Nov 16, 2001 05:38 PM
