Head Swap LX to EX
Old Mar 14, 2005
civicly's Avatar
civicly is an unknown quantity at this point
Question Head Swap LX to EX
Im swapping my Lx head to an Ex head, I noticed that the exhaust Manfold on the Ex doesnt have the cat on it like the Lx does. my question is .... will the lx exhaust work with my new EX head???
anybody with some info will be a big help.
Old Mar 15, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
well if you are swaping the head. i don't see a problem using a lx header and cat. you are just changing the head not the header.
Old Mar 15, 2005
bradmanuwf's Avatar
bradmanuwf will become famous soon enough
you can use the lx exhaust with the ex head, its just really restrictive. you should convert to an ex exhaust also. you'll also have to get an ex sway bar so the ex exhaust will fit. its like $35 on majestichonda. buy a header, higher flow cat, cat-back, simulator chip and sway bar...then you'll be a little quicker....
Old Mar 15, 2005
iamboo's Avatar
Retired - SoCal FI Mod
this topic has been disscussed in several threads... for the amount of money and time that you invest, you only gain like 4 or 5 hp at the most...
it's not like a hybrid head swap on a B series motor where you can do like a LS-Vtec type of setup... but it's your money...
lemme give you a couple threads about it... and i'll let you decide whether you still want to do it or not...
http://www.7thgencivic.com/forums/sh...d.php?t=199754
http://www.7thgencivic.com/forums/sh...d.php?t=188559
http://www.7thgencivic.com/forums/sh...d.php?t=169411
Old Mar 15, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
only if you are doing the work urself, it is worth it. other than that no.
if u want real power go w/ a 50 shot or turbo.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
Chronic_issues
May 8, 2015 05:40 PM
Drk01Civic
Jan 23, 2002 06:33 PM
supercivic01
South
Nov 30, 2001 11:27 AM
